Subject: RE: SIP Reason code inside the JTapi cisco cause codes whne a call hangup
Replied by: James Wagner on 05-04-2012 07:07:13 PM
I also have an Asterisk server interfacing with the CCM via a SIP trunk. However, I haven't programmed anything with it and so have 0 practical experience with it. I did have an idea when reading your post that I figured wouldn't hurt to throw out there - maybe it'll help.
The Cisco JPAPI interface is basically an extension of regular JTAPI. You might be able to use the standard JTAPI events, rather than their Cisco-specific implementations, to retrieve the information you're looking for.
It's worth a shot at least...
Replied by: Stefania Oliviero on 06-04-2012 05:10:50 AM
Thank for your answer. I log all events received from CUCM, but I don't see any cause or reason that I've customized in the SIP protocol.
Is there a way to put a custom cause or reason code so I can then read with JTapi Events ?
This document was generated from CDN thread
Created by: Stefania Oliviero on 05-04-2012 05:36:52 PM
HI to all,
I'm trying to read the SIP reason code I put inside the Bye command via the SIPP tool.
I'd like to read this code when a call hangs up.
Scenario is:
Asterisk connected to CUCM via a SIP Trunk. My client would receive special reason code, from the calling phone, when the caller hansg up.
Can I obtain this code in the cisco cause code inside some JTapi events such as
CallCtlConnFailedEv or in a TermConDroppedEv ?
Thanks to anyone who wants to help me, this is very important for me.
Replied by: Mohan Potluri on 06-04-2012 12:31:16 PM
In addition to the standard getCause() and getCallCtrlCause(), Cisco extenstions has getCiscoCause(). If you haven't tried it already, you can give it a spin.
Replied by: Stefania Oliviero on 10-04-2012 08:37:06 AM
I've found the solution:
I put on the BYE SIP Command the following field:
Reason: Q.850;cause=6
so I can then read it with Cisco Extention getCiscocause().
I use the Q.850 codes (6 is an example). Also on the IPPhone I can view the descriptions associated with the codes.
