Created by: Gary Bradford on 19-08-2009 08:26:13 PM I am new to IP Phone programming and really dont know where to start (getting started link is dead). I think what I am trying to do is really simple. We have 7975 touchscreen phones. We simply want to put 6 ICONS on the main screen (not services) and have someone push that icon to dial a number. Any initial direction would be helpful Thanks
Subject: RE: Speed Dials on Color Touchscreen Phone Replied by: David Staudt on 19-08-2009 10:41:42 PM I would suggest using the 'Idle URL' feature. This URL can be configured per phone or globally (Enterprise Parameters), and will be retrieved when the phone goes Idle (after a call or an XML services session) after a configurable time period. The URL would point to your web server, which would serve a CiscoIPPhoneGraphicFileMenu object. This object allows a large (but not full screen) image to be displayed with configurable <TouchArea>s - which are X/Y rectangles associated with 'action' URIs. Normally these URIs would be for other URLs, but you can also specify a URI which causes the phone to dial, i.e. 'Dial:XXX' (where XXX is the number.) <?xml version="1.0" encoding="UTF-8"?> <CiscoIPPhoneGraphicFileMenu> <Title>Image Title goes here</Title> <Prompt>Prompt text goes here</Prompt> <LocationX>Horizontal position of graphic</LocationX> <LocationY>Vertical position of graphic</LocationY> <URL>Points to the PNG background image</URL> <MenuItem> <Name>Same as CiscoIPPhoneGraphicMenu</Name> <URL>Dial:1000</URL> <TouchArea X1="left edge" Y1="top edge" X2="right edge" Y2="bottom edge"/> </MenuItem> </CiscoIPPhoneGraphicFileMenu>
Subject: RE: Speed Dials on Color Touchscreen Phone Replied by: JUSTIN RILEY on 24-08-2009 07:44:20 PM I have tried this using an image size of 320x212. It does not seem to work, but I am not sure if the .xml is properly formed, or if I have webserver permission problem. I get an error 404 trying to connect to the webserver (WAMP2.0) on my laptop. I have disabled the firewall. The idle.html and hotel.png files ar both in th www root folder. Here is my take at your code: I wasn' sure what to put in the <name> tag <?xml version="1.0" encoding="UTF-8"?> <CiscoIPPhoneGraphicFileMenu> <Title>hotel</Title> <Prompt>touch an icon</Prompt> <LocationX>0</LocationX> <LocationY>0</LocationY> <URL>http://10.180.2.3/hotel.png</URL> <MenuItem> <Name>hotel</Name> <URL>Dial:1295</URL> <TouchArea X1="0" Y1="0" X2="320" Y2="212"/> </MenuItem> </CiscoIPPhoneGraphicFileMenu>
Any thoughts?
Subject: RE: Speed Dials on Color Touchscreen Phone Replied by: David Staudt on 25-08-2009 04:38:40 PM The object looks OK to me. Note the image display size is smaller than 320 - the image cannot be full screen. See the IPPS developer guide for specific displayable sizes per model. Certainly if you can't retrieve the XML object from a standard web browser, the phone will have problems.
