Matthew Limbrick
This document provides instructions for setting up the T3 document camera as Ethernet in the Installation Wizard, on TCU 4.2 via a single USB to Ethernet Adapter on the TCU side and an ethernet only connection on the document camera side. This method creates a second ethernet adapter on the TCU to use to commumicate to the document camera. Only WolfVision Document Camera version VZ- C12^2(serial number 1009412 and upwards) support this method.
The alternate connection USB in the Installation Wizard uses 2 USB to ethernet adapaters, 1 on the TCU side, and the other on the document camera side. This method is essentially a USB connection between the TCU and document camera with ethernet being used between the 2 adapters to extend the USB signal range. This configuration is not mentioned in this document.
