Matthew Limbrick
The attached Excel provides all T3 Total TelePresence software versions  that are minimal and manditory for each version of Total TelePresence  release as per the release notes. Links to all releases notes are also  provided in the attachment
T3 Total TelePresence compatibility Matrix
As per the heartbleed patch, the latest current supported software is TCU4.2.1 with codec version TC6.0.3. These 2 versions MUST be used together. Any combination other than these are not supported. For all other devices in the Total TelePresence 4.2.1 package, the minimal is still TPS 2.3(1.55), Supervisor 2.3(1.31) and TMS 14.1.1. Version of these 3 device can be higher, but not lower.
As some may note having seen release notes that TC6.3.1 was released for the TS to address the HeartBleed issue, this version is not provided on the "Cisco TelePresence System T3" download page. As seen in the screen shot below, only TC6.0.3 is listed next to TCU4.2.1 software for download. Please use these 2 software combinations.
http://software.cisco.com/download/release.html?mdfid=283644993&flowid=21862&softwareid=280886992&release=TC6.0.3&relind=AVAILABLE&rellifecycle=&reltype=latest
The attached Excel provides all T3 Total TelePresence software versions that are minimal and mandatory for each version of Total TelePresence release as per the release notes. Links to all releases notes are also provided in the attachment
Please note that T3 Total TelePresence TT4.2.0 is no longer available for download from Cisco.com as TC5.1.0 software was deferred due to an inter-op bug with the Precision HD 1080p 4x Camera. As the T3 uses a specialized Precision HD 1080p 12x camera with 4 built-in microphones (CTS-PHD-1080P12XG=), this should not be an effect. The 1st link below is the deferral notice and the second link is where TC5.1.0 software can still be downloaded from the legacy Tandberg site
http://www.cisco.com/en/US/docs/telepresence/endpoint/software/tc5/release_notes/tc5xx_deferral_notice.pdf
ftp://ftp.tandberg.com/pub/software/total_telepresence/total_telepresence4_2_0/TC/
ma.romero
Level 2
Level 2
Good document.
tneusen
good document for all the versions
