Introduction
This document explains high level feature Comparison between different CUCM versions and some CUCM 10.0 specific features.
High Level Feature Comparision
![](/legacyfs/online/media/cisco_ucm_feature_matrix.png)
CUCM 10.0 Specific Features:
1. Call Routing:
Routing Enhancements – No Inter Digit Timer Using Urgent Translation
Translation Pattern Calling Search Space Inheritance
Routing Enhancements – Ability to make DNs Urgent Priority
Multiple Local Route Group
2. Install/Upgrade and Platform:
Simplified Installation, Upgrade and Migration
Single-step change IPhostname on CUCM cluster
Prime Collaboration Deployment (PCD)
Virtualization Only (no Bare Metal)
VM Dynamic Disk Size Reallocation
64 Bit RHEL6 OS VOS
3. Video
CTI Video Support
Directory URI Configuration for Video Endpoint
Video on Hold and CTI video support for video-enabled contact center
4. Provisioning
Self Care Portal
Self Provisioning IVR
5. Security
SAML SSO (Single Sign-On simplified)
Encryption without CTLClient/Token
Security By Default(SBD Enhancements)
CA Signed LSC
6. Media
Caller-Specific MoH
H265 Codec Support
X-H264UC Codec Support / H.264-SVC Support / X-ULPFECUC support
Gateway Recording Media Forking – Call Processing
Extend Gateway Recording to CTI ports
7. Integrated admin, serviceability and user options for IM/P Services
8. Smart Call Home Enhanced
9. Database Replication Enhancements (More Rugged/Faster)
CUCM 10.0.1 feature listing,
New and Changed Information for Cisco Unified Communications Manager, Release 10.0(1)
For more information about New features and capabilities, New with Cisco Unified Communications Manager Version 10.0
Related Information
