aostense
This document is a quick reference handbook for basic troubleshooting on Telepresence infrastructures.
It also describes which logs you need, to identify different problem scenarios, for our Telepresence infrastructure products.
Updated June 2012:
- Added Log framework diagrams
- Added Advanced Media Gateway, Telepresence Server, MSE8000
Let me know if you have any questions.
Arne Østensen
Justin Ferello
Level 5
Level 5
Arne,
Great document, use it all the time.  Got a question though.  On page 25, there is a chart that references a 'serial log' for the Codian line of products.  I see no mention of how to obtain this log or what it is.  Can you elaborate on it?
Justin
natroxby
Hi Justin,
With regards to the "serial log" for the Codian products, this is similar to a generic "console login" for Cisco routers and switches. The specific way to login to the Codian devices via serial with baud rate etc, is documented on page 16 of the same Infrastructure handbook. You would only normally need to gather a serial log when a Codian device is rebooting and we are not seeing enough information output in the diagnostic information file.
Cheers,
Nathan.
