Ayodeji Okanlawon
DTMF play an important role in telephony solution as we all know. This document attempts to look at the detail traces from CUCM and gateway logs so as to understand DTMF interaction and how to troubleshoot them.
Two key elements to this:
1. DTMF supported by the Phone or IVR or unity connection
2. DTMF negotiated between CUCM and the associated gateway (sip trunk, h323 gateway or mgcp gateway)
DTMF mismatch often arise from different DTMF method supported by the two endpoints in a call. By endpoints here I mean a Phone/IVR/voicemail application and the gateway/trunk
We will be looking at different DTMF scenarios and look at both cucm and gateway logs
In all these test CUCM sip trunk dtmf method is set to No preference
SCENARIO 1:
  • Cisco Jabber for windows, SIP-KPML configured on gateway dial-peer
jabber4windows----SIP----CUCM--SIP---Gateway---E1--PSTN
  • Gateway dial-peer config
dial-peer voice 3 voip
incoming called number .
no vad
dtmf-relay sip-kpml
Let’s look at the relevant section of the logs
  • CUCM Logs:
This is the outbound CUCM INVITE sent to the Gateway
10:59:28.180 |//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 172.10.104.32:[5060]:
[311079,NET]
INVITE sip:908446930701@172.10.104.32:5060 SIP/2.0
Via: SIP/2.0/UDP 172.10.40.11:5060;branch=z9hG4bK25e275fb33fa2
From: "Deji okanlawon" <sip:01215246408@172.10.40.11>;tag=155101~ffa80926-5fac-4dd6-b405-2dbbc56ae9a2-544608971
To: <sip:908446930701@172.10.104.32>
Date: Fri, 24 May 2013 09:59:28 GMT
Call-ID: 9de24580-19f13a00-25c63-b28690a@172.10.40.11
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Call-Info: <sip:172.10.40.11:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 2648851840-0000065536-0000000282-0187197706
Session-Expires: 84600
P-Asserted-Identity: "Deji okanlawon" <sip:01215246408@172.10.40.11>
Remote-Party-ID: "Deji okanlawon" <sip:01215246408@172.10.40.11>;party=calling;screen=yes;privacy=off
Contact: <sip:01215246408@172.10.40.11:5060>;video;bfcp
Max-Forwards: 69
Content-Length: 0
This is the 183 Session progress we get back from the gateway. Note the DTMF advertised in the SDP
NO RTP-NTE
SIP/2.0 183 Session Progress
To: <sip:908446930701@172.10.104.32>;tag=4F448086-750
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: kpml, telephone-event
Remote-Party-ID: <sip:08446930701@172.10.104.32>;party=called;screen=no;privacy=off
Contact: <sip:908446930701@172.10.104.32:5060>
Supported: sdp-anat
Server: Cisco-SIPGateway/IOS-12.x
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 217
v=0
o=CiscoSystemsSIP-GW-UserAgent 9228 1435 IN IP4 172.10.104.32
s=SIP Call
c=IN IP4 172.10.104.32
t=0 0
m=audio 16384 RTP/AVP 18
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=ptime:20
Next we see CUCM telling us the DTMF capabilites of the two endpoints (sip trunk and gateway
NB: The "mLocalDtmfCaps" (highlighted) refers to the dtmf methods supported by CUCM...Here we see that CUCM supports unsolicited, KPML and RTP-NTE
On the right hand side after the mEndppointsDtmfCaps (highlighted blue) refers to the dtmf supported by the gateway: which we can see is only KPML. We can see in the trace CUCM detects no inband support
10:59:28.427 |//SIP/SIPCdpc(22,74,282)/ci=544608971/ccbId=155101/scbId=0/updateAllowedMethods: mEndpointAllowedMethods=07ff|22,100,230,1.155730^172.10.104.32^*
10:59:28.427 |setEndpointsDtmfCaps: KPML Supported.|*^*^*
10:59:28.427 |setEndpointsDtmfCaps: Detected NO inband DTMF support.|*^*^*
10:59:28.427 |SIP DTMF Info: mLocalDtmfCaps...UNSOL=1, KPML=1, Inband=1(101) mEndppointsDtmfCaps...UNSOL=0, KPML=1, Inband=0(0) mDefaultTelephonyEvent=101, mDtmfPreference=1, mMtpAllocated=0|*^*^*
Looking at the advertised capabilites, both sides support KPML, KPML is chosing as the dtmf transport method
NB: The ACK sent out to the gateway by CUCM doesn’t advertise RFC2833
10:59:30.684 |//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 172.10.104.32:[5060]:
[311084,NET]
ACK sip:908446930701@172.10.104.32:5060 SIP/2.0
Via: SIP/2.0/UDP 172.10.40.11:5060;branch=z9hG4bK25e2860b3d2ab
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 182
v=0
o=CiscoSystemsCCM-SIP 155101 1 IN IP4 172.10.40.11
s=SIP Call
c=IN IP4 172.10.40.190
t=0 0
m=audio 23012 RTP/AVP 18
a=ptime:20
a=fmtp:18 annexb=no
The next thing we see is that the gateway sends a subscribe for KPML event
10:59:30.695 |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 906 from 172.10.104.32:[52877]:
[311085,NET]
SUBSCRIBE sip:01215246408@172.10.40.11:5060 SIP/2.0
Via: SIP/2.0/UDP 172.10.104.32:5060;branch=z9hG4bKC1AF6
From: <sip:908446930701@172.10.104.32>;tag=4F448086-750
To: "Deji okanlawon" <sip:01215246408@172.10.40.11>;tag=155101~ffa80926-5fac-4dd6-b405-2dbbc56ae9a2-544608971
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
Date: Fri, 24 May 2013 09:59:30 GMT
User-Agent: Cisco-SIPGateway/IOS-12.x
Event: kpml
Expires: 7200
Contact: <sip:172.10.104.32:5060>
Content-Type: application/kpml-request+xml
Content-Length: 327
<?xml version="1.0" encoding="UTF-8"?><kpml-request xmlns="urn:ietf:params:xml:ns:kpml-request" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:ietf:params:xml:ns:kpml-request kpml-request.xsd" version="1.0"><pattern persist="persist"><regex tag="dtmf">[x*#ABCD]</regex></pattern></kpml-request>
Next CUCM sends a 200 OK to the SUBSCRIBE
10:59:30.695 |//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 172.10.104.32:[5060]:
[311086,NET]
SIP/2.0 200 OK
CSeq: 101 SUBSCRIBE
Expires: 7200
Content-Length: 0
Once the endpoint successfully subscribe to KPML,CUCM sends a NOTIFY for KPML event,this is how DTMF will be sent out
NOTIFY sip:172.10.104.32:5060 SIP/2.0
Via: SIP/2.0/UDP 172.10.40.11:5060;branch=z9hG4bK25e29422465a0
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: kpml
Subscription-State: active;expires=7200
Content-Length: 0
We get 200 OK from gateway
10:59:30.705 |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 380 from 172.10.104.32:[5060]:
[311088,NET]
SIP/2.0 200 OK
CSeq: 102 NOTIFY
Content-Length: 0
Now we see the actual DTMF digits been SENT Look out for the "star_CcUserInfoReq" line..
for each digit pressed this line is generated and you see the actual digit
10:59:35.969 |//SIP/SIPCdpc(22,74,282)/ci=544608971/ccbId=155101/scbId=0/star_CcUserInfoReq: Outbound DTMF method selected is 3. Digit=0 and isMTPPassingThru2833=0|23,100,63,1.1151^172.10.40.190^*
Next we see CUCM sends the digit received out via KPML
NB: we do not see the “KeypadButton” message in this trace because the IP phone is not registered to the CUCM in the sip trunk CUCM group. This trace exists on that CUCM.
10:59:35.969 |//SIP/SIPCdpc(22,74,282)/ci=544608971/ccbId=155101/scbId=155102/sendDtmfViaKpml: ccUserInfoReq.digit=0|23,100,63,1.1151^172.10.40.190^*
10:59:35.969 |//SIP/SIPCdpc(22,74,282)/ci=544608971/ccbId=155101/scbId=155102/sendDtmfViaKpml: notifyContent->mDigits=0|23,100,63,1.1151^172.10.40.190^*
Next we see CUCM sending the digit to the gateway via a NOTIFY
To see the actual digit look into the xml encoding of the NOTIFY message, you can see digit=0
10:59:35.969 |//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 172.10.104.32:[5060]:
[311089,NET]
Via: SIP/2.0/UDP 172.10.40.11:5060;branch=z9hG4bK25e2a78a7f435
CSeq: 103 NOTIFY
Max-Forwards: 70
Date: Fri, 24 May 2013 09:59:35 GMT
Event: kpml
Subscription-State: active;expires=7195
Content-Type: application/kpml-response+xml
Content-Length: 336
<?xml version="1.0" encoding="UTF-8" ?>
<kpml-response xmlns="urn:ietf:params:xml:ns:kpml-response" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:ietf:params:xml:ns:kpml-response kpml-response.xsd" code="200" digits="0" forced_flush="false" suppressed="false" tag="dtmf" text="Success" version="1.0"/>
Finally we get a 200 OK to the NOTIFY from the gateway
10:59:35.979 |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 380 from 172.10.104.32:[5060]:
[311090,NET]
SIP/2.0 200 OK
CSeq: 103 NOTIFY
Content-Length: 0
On The gateway we see this...
080984: May 24 10:59:35.905 BST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 103 NOTIFY
Max-Forwards: 70
Event: kpml
Content-Length: 336
080985: May 24 10:59:35.905 BST: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 103 NOTIFY
Content-Length: 0
  • Hence can see and conclude that the gateway receives the digits sent by CUCM
SCENARIO 2
  • SCCP Phone-7941G, rtp-nte configured on gateway dial-peer
IPPhone--sccp--CUCM--SIP---Gateway---E1--PSTN
no vad
dtmf-relay rtp-nte
I am going to skip the SIP signalling messages and go to the DTMF negotiation bit
Here we see the 200 OK sent to CUCM from the gateway and we see rtp-nte advertised in the SDP
16:59:41.964 |//SIP/SIPUdp/wait_UdpDataInd: Incoming SIP UDP message size 1119 from 172.10.104.32:[5060]:
[289744,NET]
SIP/2.0 200 OK
Via: SIP/2.0/UDP 172.10.40.11:5060;branch=z9hG4bK2348d9c6fccc
From: "Strand" <sip:02070043000@172.10.40.11>;tag=144444~ffa80926-5fac-4dd6-b405-2dbbc56ae9a2-392166160
To: <sip:908446930701@172.10.104.32>;tag=3BF6421A-410
Date: Mon, 20 May 2013 15:59:39 GMT
Call-ID: 45642d00-19a1486b-232d7-b28690a@172.10.40.11
CSeq: 101 INVITE
Allow-Events: telephone-event
Supported: replaces
Supported: sdp-anat
Session-Expires: 84600;refresher=uac
Require: timer
Content-Length: 273
v=0
o=CiscoSystemsSIP-GW-UserAgent 2394 1999 IN IP4 172.10.104.32
s=SIP Call
t=0 0
m=audio 18984 RTP/AVP 18 101
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
Observe the DTMF capabilities on the SIP DTMF info
CUCM DTMF capabilites negotiation
16:59:42.037 |setLocalDtmfCaps: supportedDTMFMethod=3, mWantDtmfReception=1, mPeersWantDtmfReceptionFlag=0, mDtmfPreference=1|*^*^*
16:59:42.037 |SIP DTMF Info: mLocalDtmfCaps...UNSOL=1, KPML=1, Inband=1(101) mEndppointsDtmfCaps...UNSOL=0, KPML=0, Inband=1(101) mDefaultTelephonyEvent=101, mDtmfPreference=1, mMtpAllocated=0|*^*^*
Next we see the ACK sent by CUCM, which includes RFC2833/RFC4733
16:59:42.037 |//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 172.10.104.32:[5060]:
[289745,NET]
Via: SIP/2.0/UDP 172.10.40.11:5060;branch=z9hG4bK2348e279e05fe
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 236
v=0
o=CiscoSystemsCCM-SIP 144444 1 IN IP4 172.10.40.11
s=SIP Call
c=IN IP4 172.10.1.69
t=0 0
m=audio 29766 RTP/AVP 18 101
a=ptime:20
a=fmtp:18 annexb=no
a=fmtp:101 0-15
As explained above we can see CUCM adverties rtp-nte , KPML and UNSOL (highlighted in green), where as the gateway only supports rtp-nte (set by dial-peer config)
Now we see the phone sending dtmf digits because dtmf is sent inband, cucm doesnt get involved in sending the digits
However in the sip stack we can still see the DTMF digits the endpoint is ending
++digit=0++
16:59:49.763 |//SIP/SIPD(22,73,28)/ccbId=0/scbId=0/getCdpcPid: found Cdpc Pid (22,100,74,268) for mapKey 392166160|23,100,13,72951.131^172.10.1.69^SEP5C5015A9D75B
16:59:49.763 |//SIP/SIPCdpc(22,74,268)/ci=392166160/ccbId=144444/scbId=0/star_CcUserInfoReq: Outbound DTMF method selected is 1. Digit=0 and isMTPPassingThru2833=0|23,100,13,72951.131^172.10.1.69^SEP5C5015A9D75B
++digits=2++
16:59:50.292 |//SIP/SIPD(22,73,28)/ccbId=0/scbId=0/getCdpcPid: found Cdpc Pid (22,100,74,268) for mapKey 392166160|23,100,13,72951.133^172.10.1.69^SEP5C5015A9D75B
16:59:50.292 |//SIP/SIPCdpc(22,74,268)/ci=392166160/ccbId=144444/scbId=0/star_CcUserInfoReq: Outbound DTMF method selected is 1. Digit=2 and isMTPPassingThru2833=0|23,100,13,72951.133^172.10.1.69^SEP5C5015A9D75B
On the gateway using debug voip rtp session named-event++ we can see the actual dtmf digits sent in RTP stream with payload 101
067897: .May 20 16:59:50.453 BST: s=VoIP d=DSP payload 0x65 ssrc 0x1DDD3867 sequence 0x60D timestamp 0xED976557
067898: .May 20 16:59:50.453 BST: <<<Rcv> Pt:101 Evt:0 Pkt:09 00 00
067899: .May 20 16:59:50.473 BST: s=VoIP d=DSP payload 0x65 ssrc 0x1DDD3867 sequence 0x60F timestamp 0xED976557
067900: .May 20 16:59:50.473 BST: <<<Rcv> Pt:101 Evt:0 Pkt:09 00 A0
067901: .May 20 16:59:50.493 BST: s=VoIP d=DSP payload 0x65 ssrc 0x1DDD3867 sequence 0x611 timestamp 0xED976557
067902: .May 20 16:59:50.493 BST: <<<Rcv> Pt:101 Evt:0 Pkt:09 01 40
067903: .May 20 16:59:50.513 BST: s=VoIP d=DSP payload 0x65 ssrc 0x1DDD3867 sequence 0x613 timestamp 0xED976557
067904: .May 20 16:59:50.513 BST: <<<Rcv> Pt:101 Evt:0 Pkt:89 01 E0
067905: .May 20 16:59:50.513 BST: s=VoIP d=DSP payload 0x65 ssrc 0x1DDD3867 sequence 0x614 timestamp 0xED976557
067906: .May 20 16:59:50.513 BST: <<<Rcv> Pt:101 Evt:0 Pkt:89 01 E0
067907: .May 20 16:59:50.533 BST: s=VoIP d=DSP payload 0x65 ssrc 0x1DDD3867 sequence 0x615 timestamp 0xED976557
067908: .May 20 16:59:50.533 BST: <<<Rcv> Pt:101 Evt:0 Pkt:89 01 E0
067909: .May 20 16:59:50.553 BST: s=VoIP d=DSP payload 0x65 ssrc 0x1DDD3867 sequence 0x623 timestamp 0xED976F57
067910: .May 20 16:59:50.553 BST: <<<Rcv> Pt:101 Evt:2 Pkt:09 00 00
067911: .May 20 16:59:50.573 BST: s=VoIP d=DSP payload 0x65 ssrc 0x1DDD3867 sequence 0x625 timestamp 0xED976F57
067912: .May 20 16:59:50.573 BST: <<<Rcv> Pt:101 Evt:2 Pkt:09 00 A0
067913: .May 20 16:59:50.593 BST: s=VoIP d=DSP payload 0x65 ssrc 0x1DDD3867 sequence 0x627 timestamp 0xED976F57
067914: .May 20 16:59:50.593 BST: <<<Rcv> Pt:101 Evt:2 Pkt:09 01 40
067915: .May 20 16:59:50.613 BST: s=VoIP d=DSP payload 0x65 ssrc 0x1DDD3867 sequence 0x629 timestamp 0xED976F57
067916: .May 20 16:59:50.613 BST: <<<Rcv> Pt:101 Evt:2 Pkt:09 01 E0
067917: .May 20 16:59:50.633 BST: s=VoIP d=DSP payload 0x65 ssrc 0x1DDD3867 sequence 0x62B timestamp 0xED976F57
067918: .May 20 16:59:50.633 BST: <<<Rcv> Pt:101 Evt:2 Pkt:89 02 80
067919: .May 20 16:59:50.633 BST: s=VoIP d=DSP payload 0x65 ssrc 0x1DDD3867 sequence 0x62C timestamp 0xED976F57
067920: .May 20 16:59:50.633 BST: <<<Rcv> Pt:101 Evt:2 Pkt:89 02 80
067921: .May 20 16:59:50.633 BST: s=VoIP d=DSP payload 0x65 ssrc 0x1DDD3867 sequence 0x62D timestamp 0xED976F57
067922: .May 20 16:59:50.633 BST: <<<Rcv> Pt:101 Evt:2 Pkt:89 02 80
SCENARIO 3:
  • Cisco 7941 with RFC2833 disabled, Exchange with rfc2833. (CUCM Inserts MTP to send rfc2833 out to exchange)
IPphone--SCCP--CUCM--------SIP-------Exchange Unified messaging
  • CUCM Logs
This is the 200 OK received from Exchange, here we see exchange advertising RFC2833/4733
00028171.006 |12:59:46.332 |AppInfo |SIPTcp - wait_SdlReadRsp: Incoming SIP TCP message from 192.168.131.40 on port 5065 index 377 with 1539 bytes:
[204,NET]
SIP/2.0 200 OK
FROM: "bob banks2"<sip:800193850@192.168.131.11>;tag=562~736dccb8-3be2-4f69-88f8-ec5946dd6872-27034350
TO: <sip:755670001@192.168.131.40>;tag=3c42c6b9c1;epid=4F9342F874
CSEQ: 101 INVITE
CALL-ID: 6aa02a80-1a713f32-1e3-b83a8c0@192.168.131.11
VIA: SIP/2.0/TCP 192.168.131.11:5060;branch=z9hG4bK1f51b101ed3
CONTACT: <sip:UCLAB-DC.uclab.com:5065;transport=Tcp;maddr=192.168.131.40>;automata;text;audio;video;image
CONTENT-LENGTH: 678
PRIORITY: Normal
SUPPORTED: Replaces
SUPPORTED: timer
SUPPORTED: 100rel
CONTENT-TYPE: application/sdp
ALLOW: ACK
P-ASSERTED-IDENTITY: <sip:755670001@192.168.131.40>
SERVER: RTCC/3.5.0.0 MSExchangeUM/14.01.0218.012
Content-ID: af19ca95-d81b-413e-8657-f90d5ea9b4aa
Allow: CANCEL,BYE,INVITE,MESSAGE,INFO,SERVICE,OPTIONS,BENOTIFY,NOTIFY,PRACK,UPDATE
Session-Expires: 1800;refresher=uac
Min-SE: 1800
v=0
o=- 11 0 IN IP4 192.168.131.40
s=session
c=IN IP4 192.168.131.40
b=CT:1000
t=0 0
m=audio 32764 RTP/AVP 114 115 112 111 116 3 4 0 8 13 118 97 101
a=rtcp:32765
a=sendrecv
a=label:main-audio
a=rtpmap:114 x-msrta/16000
a=fmtp:114 bitrate=29000
a=rtpmap:115 x-msrta/8000
a=fmtp:115 bitrate=11800
a=rtpmap:112 G7221/16000
a=fmtp:112 bitrate=24000
a=rtpmap:111 SIREN/16000
a=fmtp:111 bitrate=16000
a=rtpmap:116 AAL2-G726-32/8000
a=rtpmap:3 GSM/8000
a=rtpmap:4 G723/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:13 CN/8000
a=rtpmap:118 CN/16000
a=rtpmap:97 RED/8000
a=fmtp:101 0-16,36
NB: From the CUCM logs we can see that CUCM DTMF info does not yet indicate that its going to do RFC2833. This is because CUCM will not send support for rfc2833 untill it allocates an MTP since the endpoint cant do rfc2833.
00028195.006 |12:59:46.337 |AppInfo |SIP DTMF Info: mLocalDtmfCaps...UNSOL=1, KPML=1, Inband=0(0) mEndppointsDtmfCaps...UNSOL=0, KPML=0, Inband=1(101) mDefaultTelephonyEvent=101, mDtmfPreference=1, mMtpAllocated=0
Next CUCM says we need MTP due to DTMF mistmatch
00028211.015 |12:59:46.338 |AppInfo |DET-MediaManager-(13)::isMTPNeededForMismatchOrConfig, MTPNeededDueToDTMFCapMismatch(2833/OOB) mtpinsertionReason=1 dtmfMTPSide=2
Next CUCM Allocates an MTP Resource
00028219.020 |12:59:46.339 |AppInfo |MediaTerminationPointControl(1)::getResourcesAllocated -- DeviceName=MTP_2 Ci=27034351 ResourceAllocated=1
Next We see CUCM updates its DTMF info and we see RFC2833/4733 advertised
00028362.002 |12:59:46.524 |AppInfo |SIP DTMF Info: mLocalDtmfCaps...UNSOL=1, KPML=1, Inband=1(101) mEndppointsDtmfCaps...UNSOL=0, KPML=0, Inband=1(101) mDefaultTelephonyEvent=101, mDtmfPreference=1, mMtpAllocated=1
Next CUCM sends an ACK advertising rtp-nte
Observe that the ip address of CUCM is where media is sent to (look at the connection parameter)
00028384.001 |12:59:46.526 |AppInfo |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 192.168.131.40 on port 5065 index 377
[205,NET]
ACK sip:UCLAB-DC.uclab.com:5065;maddr=192.168.131.40;transport=Tcp SIP/2.0
Via: SIP/2.0/TCP 192.168.131.11:5060;branch=z9hG4bK1f61b97d076
From: "bob banks2" <sip:800193850@192.168.131.11>;tag=562~736dccb8-3be2-4f69-88f8-ec5946dd6872-27034350
To: <sip:755670001@192.168.131.40>;tag=3c42c6b9c1
Date: Thu, 30 May 2013 11:59:46 GMT
Call-ID: 6aa02a80-1a713f32-1e3-b83a8c0@192.168.131.11
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 224
v=0
o=CiscoSystemsCCM-SIP 562 1 IN IP4 192.168.131.11
s=SIP Call
c=IN IP4 192.168.131.11
b=CT:64
t=0 0
m=audio 24584 RTP/AVP 8 101
a=ptime:20
a=fmtp:101 0-15
NEXT we see the DTMF digit pressed on the phone
++digit pressed=1++
00028404.001 |12:59:51.296 |AppInfo |StationInit: (0000006) KeypadButton kpButton=1
Next CUCM chooses the outbound method to use to send the digit
From my experience, here are the DTMF methods you will see in CUCM traces
  • RFC2833--- Outbound DTMF method = 1
  • OOB---RFC2833-- Outbound DTMF method=2
  • KPML---- Outbound DTMF method=3
00028412.001 |12:59:51.297 |AppInfo |SIPCdpc(11) - star_CcUserInfoReq: Outbound DTMF method selected is 2. Digit=1 and isMTPPassingThru2833=0
00028412.002 |12:59:51.297 |AppInfo |SIPCdpc(11) - sendDtmfVia2833: sending sipOutgoingDTMFTone Tone 1 for digit 1.
Next we see MTP receiving dtmf pressed on the phone, NB the phone sending the digit and trhe digit sent
00028416.000 |12:59:51.297 |SdlSig |MXOutgoingDTMFTone |waiting |MediaTerminationPointControl(1,100,130,1) |MTPAgenaInterface(1,100,233,6) |1,100,13,79.26^192.168.131.60^SEP001BD584B00D |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] tone=1 CI=27034351 confId=16779219 passthruPartyID=0x1000013 isMTPPassingThru2833=F
Here we see the MTP process on CUCM sending tone=1 out to exhchange
00028416.001 |12:59:51.297 |AppInfo |MediaTerminationPointControl(1)::star_MediaExchangeOutgoingDTMFTone tone=1, conferenceID=16779219, passthruID=16777235
00028416.002 |12:59:51.297 |AppInfo |MediaTerminationPointControl(1)::star_MediaExchangeOutgoingDTMFTone TCPPid = [1.100.13.4] myIP: 0xb83a8c0 (192.168.131.11) conferenceID=16779219, passthruPartyID=16777235, tone=1
Next we see another digit (2) pressed on the phone
00028424.001 |12:59:51.808 |AppInfo |StationInit: (0000006) KeypadButton kpButton=2.
00028432.001 |12:59:51.808 |AppInfo |SIPCdpc(11) - star_CcUserInfoReq: Outbound DTMF method selected is 2. Digit=2 and isMTPPassingThru2833=0
00028432.002 |12:59:51.808 |AppInfo |SIPCdpc(11) - sendDtmfVia2833: sending sipOutgoingDTMFTone Tone 2 for digit 2
00028436.000 |12:59:51.808 |SdlSig |MXOutgoingDTMFTone |waiting |MediaTerminationPointControl(1,100,130,1) |MTPAgenaInterface(1,100,233,6) |1,100,13,79.27^192.168.131.60^SEP001BD584B00D |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] tone=2 CI=27034351 confId=16779219 passthruPartyID=0x1000013 isMTPPassingThru2833=F
Here we see the MTP process on CUCM sending tone=2 out
00028436.001 |12:59:51.808 |AppInfo |MediaTerminationPointControl(1)::star_MediaExchangeOutgoingDTMFTone tone=2, conferenceID=16779219, passthruID=16777235
00028436.002 |12:59:51.808 |AppInfo |MediaTerminationPointControl(1)::star_MediaExchangeOutgoingDTMFTone TCPPid = [1.100.13.4] myIP: 0xb83a8c0 (192.168.131.11) conferenceID=16779219, passthruPartyID=16777235, tone=2
We can also take wiresshark captures from CUCM and we will see the actual "rtpevent" sent out and the digits sent. The screen shot below shows the wireshark cpatures taking from CUCM and the RFC2833 formatted digits sent out to exchange.
From the wireshark traces, we can see the digit been sent out by the MTP to the exchange server.
SCENARIO 4:
  • Cisco Jabber for windows, SIP-KPML and rtp-nte configured on gateway dial-peer
jabber4windows--SIP---CUCM--SIP---Gateway---E1--PSTN
no vad
dtmf-relay sip-kpml rtp-nte
Here we can see that both endpoint support KPML and rtp-nte
14:53:48.445 |setEndpointsDtmfCaps: KPML Supported.|*^*^*
14:53:48.445 |setEndpointsDtmfCaps: Detected inband DTMF support.|*^*^*
14:53:48.445 |SIP DTMF Info: mLocalDtmfCaps...UNSOL=1, KPML=1, Inband=1(101) mEndppointsDtmfCaps...UNSOL=0, KPML=1, Inband=1(101) mDefaultTelephonyEvent=101, mDtmfPreference=1, mMtpAllocated=0|*^*^*
When both endpoint support rtp-nte regardless of the dtmf preference configured on the gateway, RTP-NTE will be negotiated and used
DTMF DIGITS
++ digit=0 ++
14:53:58.898 |//SIP/SIPD(22,73,33)/ccbId=0/scbId=0/getCdpcPid: found Cdpc Pid (22,100,74,286) for mapKey 544627160|23,100,63,1.1271^172.10.40.190^*
14:53:58.898 |//SIP/SIPCdpc(22,74,286)/ci=544627160/ccbId=155570/scbId=0/star_CcUserInfoReq: Outbound DTMF method selected is 1. Digit=0 and isMTPPassingThru2833=0|23,100,63,1.1271^172.10.40.190^*
++ digit=2 ++
14:54:01.948 |//SIP/SIPD(22,73,33)/ccbId=0/scbId=0/getCdpcPid: found Cdpc Pid (22,100,74,286) for mapKey 544627160|23,100,63,1.1272^172.10.40.190^*
14:54:01.948 |//SIP/SIPCdpc(22,74,286)/ci=544627160/ccbId=155570/scbId=0/star_CcUserInfoReq: Outbound DTMF method selected is 1. Digit=2 and isMTPPassingThru2833=0|23,100,63,1.1272^172.10.40.190^*
Here we see the rtp event received on the gateway
082055: May 24 14:53:58.743 BST: s=VoIP d=DSP payload 0x65 ssrc 0xDCC07A11 sequence 0x3B6B timestamp 0xA892DC55
082056: May 24 14:53:58.743 BST: <<<Rcv> Pt:101 Evt:0 Pkt:0A 01 90
082057: May 24 14:53:58.793 BST: s=VoIP d=DSP payload 0x65 ssrc 0xDCC07A11 sequence 0x3B6C timestamp 0xA892DC55
082058: May 24 14:53:58.793 BST: <<<Rcv> Pt:101 Evt:0 Pkt:0A 01 90
082059: May 24 14:53:58.843 BST: s=VoIP d=DSP payload 0x65 ssrc 0xDCC07A11 sequence 0x3B6D timestamp 0xA892DC55
082060: May 24 14:53:58.843 BST: <<<Rcv> Pt:101 Evt:0 Pkt:0A 03 20
082061: May 24 14:53:58.893 BST: s=VoIP d=DSP payload 0x65 ssrc 0xDCC07A11 sequence 0x3B6E timestamp 0xA892DC55
082062: May 24 14:53:58.893 BST: <<<Rcv> Pt:101 Evt:0 Pkt:0A 04 B0
082063: May 24 14:53:58.943 BST: s=VoIP d=DSP payload 0x65 ssrc 0xDCC07A11 sequence 0x3B6F timestamp 0xA892DC55
082064: May 24 14:53:58.943 BST: <<<Rcv> Pt:101 Evt:0 Pkt:0A 06 40
082065: May 24 14:53:58.993 BST: s=VoIP d=DSP payload 0x65 ssrc 0xDCC07A11 sequence 0x3B70 timestamp 0xA892DC55
082066: May 24 14:53:58.993 BST: <<<Rcv> Pt:101 Evt:0 Pkt:8A 07 D0
082067: May 24 14:54:01.800 BST: s=VoIP d=DSP payload 0x65 ssrc 0xDCC07A11 sequence 0x3BFB timestamp 0xA8933BD5
082068: May 24 14:54:01.800 BST: <<<Rcv> Pt:101 Evt:2 Pkt:0A 01 90
082069: May 24 14:54:01.848 BST: s=VoIP d=DSP payload 0x65 ssrc 0xDCC07A11 sequence 0x3BFC timestamp 0xA8933BD5
082070: May 24 14:54:01.848 BST: <<<Rcv> Pt:101 Evt:2 Pkt:0A 01 90
082071: May 24 14:54:01.900 BST: s=VoIP d=DSP payload 0x65 ssrc 0xDCC07A11 sequence 0x3BFD timestamp 0xA8933BD5
082072: May 24 14:54:01.900 BST: <<<Rcv> Pt:101 Evt:2 Pkt:0A 03 20
082073: May 24 14:54:01.950 BST: s=VoIP d=DSP payload 0x65 ssrc 0xDCC07A11 sequence 0x3BFE timestamp 0xA8933BD5
082074: May 24 14:54:01.950 BST: <<<Rcv> Pt:101 Evt:2 Pkt:0A 04 B0
082075: May 24 14:54:02.000 BST: s=VoIP d=DSP payload 0x65 ssrc 0xDCC07A11 sequence 0x3BFF timestamp 0xA8933BD5
082076: May 24 14:54:02.000 BST: <<<Rcv> Pt:101 Evt:2 Pkt:0A 06 40
082077: May 24 14:54:02.050 BST: s=VoIP d=DSP payload 0x65 ssrc 0xDCC07A11 sequence 0x3C00 timestamp 0xA8933BD5
082078: May 24 14:54:02.050 BST: <<<Rcv> Pt:101 Evt:2 Pkt:8A 07 D0
Hence we see that even though sip-kpml was the preffered method on the dial-peer rtp-nte was used..As long as both endpoints support it, it will be used
For more troubleshooting tips, please refer to this excellent post from Lavanya
https://supportforums.cisco.com/community/netpro/collaboration-voice-video/ip-telephony/blog/2013/05/27/understanding-sip-dtmf-options-supported-by-cucm
As always excellent document ! Very Informative.
Lavanya
Sarg .
Level 3
Level 3
You have done really well to have created this doc. Truly a hard working guy.
Great Job!
Ayodeji Okanlawon
Thank you my brother. Kind words from you
Manish Gogna
I have come across this doc many times, made sure to rate it this time for the excellent work.
Manish
Ayodeji Okanlawon
Thank you Manish. Really appreciate the feedback.
Deepak Mehta
Great Doc.thanks
What a great article! You are the man of honor! I wish I could  be as great person as you are. You truly inspired me.
Moshfiqur
Ayodeji Okanlawon
Moshfiqur,
Thank you for the nice compliment, I really appreciate it.
HI, awesome post, thank you. Just to clarify: Do these mLocalDtmfCaps and mEndppointsDtmfCaps depend on who is caller and who is called ? Or is mLocaldtmfcaps = CUCM always? I have some calls were failing until i unchecked MTP required on my sip trunk. so traces were shoving Local and endpoint were sending SIP DTMF Info: many times , once with unsol=1, then w/ inband=1, then kpml=1 and I guess they could not agreed :D . I was lucky MTP uncheck resolved my issue. Have u had any such experience or do u have any thoughts why it may happened? just curiosity to understand the cause of the issue. Thank you
arielroza
Hi Ayodeji Okanlawon,
Can you hightlight the relevant portions of the SIP messages, as you did in the CUCM logs? The article, although nice is a bit hard to read for those of us who are not wholy trained in all the details of them.
Thanks!
