Brett Fritzsch
Introduction:
Bulk Administration Tool (BAT) is a tool that can be used to make the editing/adding/removing of multiple phones
quicker and easier.  Although its designed to make things easier for users to add/remove/update administrators
commonly run into issues.  The following is a guide that will show you how to edit multiple phone descriptions
using this tool.
Steps:
1. Bulk Administration ---> Phones --> Export Phones --> All Details
2. Choose all phone types, give a file name, Run immediately
3. Monitor the Job and wait for it to show as completed in Job Scheduler
4. Bulk Administration --> Upload/Download files.... Download the file to your desktop
5. Import into excel using comma delimited
     Office 2003:
     Office 2007:
6. Find the Description column
7. Saved the file as a CSV
8. Next we need to upload the CSV that we created:
     Bulk Administration --> Upload/download files -->  Add New
     Choose file from your desktop
     Target = Phones
     Transaction Type =  Insert Phones - All Detail
     Save
9. Bulk Administration --> Phones --> Insert Phones
10. Check Insert Phones All Detail --> select file --> Check Override the existing config --> Run Immediately --> Submit
11. Confirm that the Job ran with no errors
     Bulk Administration --> Job Scheduler --> Click on the Job Name
12. Check phone page to make sure change took effect.
jcompiano
Beginner
Beginner
Good tip, i was spinning my wheels trying to use the BAT update process to update my descriptions. Good to know it's actually under install phones to update.
thanks
Gia Reynolds
Beginner
Beginner
I am trying to use the Bulk Administration to setup new users with Extension Mobility. I found the document below but the instructions are unclear. Has anyone used Bulk Administration for  Extension Mobility?
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080b35d02.shtml#csv
Michael Endler
Beginner
Beginner
Awesome, cutted extremly my research and labtime!
o.artigny
Beginner
Beginner
There seems to be a bug with the phone export when the export format contains the owner used ID field.
CSCtb95233
I have to populate that field to cope with the new licences format.
How may I proceed ?
Olivier
christianbernal
Beginner
Beginner
When you save the .csv in excel, the archive is separated with (;) is necesary replaze in one notepad for (,) the rest is fine
Thanks is very util :)
KNYC
Beginner
Beginner
Anyone is getting an error that Line Text Label is not a valid field? Even though it is in exported file.
Line Text Label is not updating.
EYC
Beginner
Beginner
I have a question when we do a export all config from CUCM, we usually use excel to manipulate the csv file. My question is there are times where the user display name field includes a comma, but we know that comma is used as a delimiter, so excel does not know if it is part of the field or as delimiter and the record goes off by a few columns. Anyone knows any way around that? Googling says use double quotation but I do not see if being included in the export csv. Anyone any ideas or recommendation? Thanks.
