Thanks for video...I understand it is 5 yrs old but It will be handy for me because I need to do similar task. My question is-If I have 'Different Types/Models' of phone, would this work? I have few 7800 and few 7900 series of phones where I need to configure a Speed Dial list.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
Hi All, Custom Tabs on Jabber for windows don't show anything when I click on them. but the same work just fine in Jabber for iOS.? Here's the code: <Client>
<jabber-plugin-config>
<browser-plugin>
<page refresh="t...
view more
please I have ccx 12.5 where I installed a subscriber by mistake without knowing that I don't have a license for it. Now im getting license compliance issue for "CCX permium warm standby 12.5" even after I removed the subscriber and restarted the publishe...
view more
Good Morning ColleaguesI hope you are doing good and safe. I have configured 2 dial-peers , One for VOIP (SIP trunk to third IP PBX) and another POTS for outbound/incoming calls to & from PSTN. The extensions at the third party IP PBX are 1x...
view more
Hello, we are service provider and have migrated to UC-One SaaS platform. The datasheet talks about pre-integrated apps and for our case I only see a plugin to integrate with outlook, no clue where to find the options to enable the integration. We are par...
view more
Hi Everyone: I am trying to figure out a Consider If Formula for an Agent ID/Peripheral Number associated with a Skill Group. Basically, I am trying to queue to an agent, and if my agent is not available, I want to queue to a skill group this a...
view more
