Call Flow :
PSTN (066222222) calls CUCM (055711711) -> internal line number 711711.
line 711711 has a CallFwdAll configured to PSTN (047411111)
line 711711 has an External Phone Number Mask configured 055711711
Behaviour :
On the Cisco Cube to the CUCM
Sent:
INVITE sip:055711711@172.16.36.12 SIP/2.0
Via: SIP/2.0/UDP 172.16.36.11:5060;branch=z9hG4bK1101F013D2
From: <sip:066222222@172.16.36.11>;tag=F2211D5E-1699
To: <sip:055711711@172.16.36.12>
P-Asserted-Identity: <sip:066222222@172.16.36.11>
From the CUCM to the Cisco Cube
Received:
INVITE sip:0474111111@172.16.36.11:5060 SIP/2.0
From: <sip:066222222@172.16.36.12>;tag=572691~5b05ad4d-fea7-417e-b8a9-04dd596f3b5b-41332605
To: <sip:0474111111@172.16.36.11>
Diversion: "test" <sip:711711@172.16.36.12>;reason=unconditional;privacy=off;screen=yes
P-Asserted-Identity: <sip:066222222@172.16.36.12>
We see that the CUCM sends the internal phone number in the diversion Header.
-> Diversion: "test" <sip:711711@172.16.36.12>;reason=unconditional;privacy=off;screen=yes
What we would like to have is the following :
-> Diversion: "test" <sip:055711711@172.16.36.12>;reason=unconditional;privacy=off;screen=yes
where the 055711711 is the content of the External Phone number mask
Working on the cube and modifing the 711711 into 055711711 whith SIP manipulation is complicated due to the DN complexity for the customers.
Some discussion talk about configuring a redirect partition and CSS and apply a transformation calling pattern, then use this CSS in the
Redirecting Diversion Header Delivery - Outbound |
Redirecting Party Transformation CSS |
but ... it doesn't seem to work and SDL trace doesn't tell me why ..
Thanks for your hints/help
Frederic
You need to apply the redirecting CSS on the SIP trunk - this CSS contains a partition and this partition should be assigned to a calling party transformation mask 711XXX and in the transformation add prefix 055.
OR
on the incoming dial peer from CallManager apply the below translation:
voice translation-rule 9999999
rule 1 /^\(711...\)/ /055\1/
voice translation-profile INC-CUCM-CFWD
translate redirect-called 1
This will match on the diversion header and change all number starting with 711XXX to 055711XXX
Ismail Moaufy
Hi Ismail,
Are you ensure that point should be translate redirect-called 9999999 not translate redirect-called 1 right ?
yes you are correct
