How to busy-out B-channels on a Catalyst 6608 module in Cisco CallManager for troubleshooting
1901
Resolution
You can gracefully "busy-out" (graceful out-of-service) 6608 module B-channels for troubleshooting purposes. This can be configured in the Cisco CallManager Administrator web pages. To do this, perform these steps:
  1. Go to the Cisco CallManager Administrator web pages.
  2. Select Service > Service Parameters.
  3. Select any server from the drop down box, and select the Cisco CallManager service from the drop down box.
  4. Click the Advanced button to display all of the advanced service parameters.
  5. Under the Cluster Wide Parameters (Device - PRI and MGCP Gateway) heading, refer to the parameter called Change B-Channel Maintenance Status 1 (with four other parameters with similar titles for status 2-5). This paramater allows the Cisco CallManager to change the individual B-channel maintenance status for PRI interface in real-time for troubleshooting.
  6. A detailed description of how to configure these advanced service parameters can be found by clicking the service parameter name to bring up the context-sensitive help.
Changes to service parameters usually require that the service which was modified is restarted before changes take effect.
For more details and configuration options, refer to the context-sensitive help for the service parameter.
For information on monitoring the B-channel status of the 6608 port configured as a MGCP PRI GW , refer the document - In Cisco CallManager, how to monitor the B-channel status of the 6608 port configured as an MGCP PRI gateway
For more information, refer to Service Parameters Configuration.
Create
Recognize Your Peers
Content for Community-Ad
