Problem
The call flow is: Telco--(SIP)--CUBE--(SIP)--CUCM--Phone
Call forwarding to PSTN line is not working when the call is originated from PSTN.
Following are the challenges for incoming calls from Telco
When a call come into the CUBE from Telco to CUCM, you want dialed number and calling number
to be transformed before send to CUCM.
a) From International caller: dialed number looks like 00966-3-813-xxxx,
but Telco will send 3813xxxx and this must become xxxx before CUBE route the call to CUCM
b) From country caller (different city): dialed number looks like 03813xxxx, but Telco will send 3813xxxx
and this must become xxxx before CUBE route the call to CUCM.
c) From country caller (same city): dialed number looks like 813xxxx. Telco will send 813xxxx
d) For calling number, you may add prefix 900 (to international number) and prefix 90 (to national number) for redial purpose.
Solution
To achieve these challenges a sample configuration on CUBE is given below.
1) Translation rule to transform called number sent by Telco (3813xxxx and 813xxxx) to xxxx as below!
voice translation-rule 1
rule 4 /^3813\(....\)/ /\1/
rule 5 /^813\(....\)/ /\1/
2) Translation rule to add prefix 900 to international number, and prefix 90 to national number as below
voice translation-rule 5
rule 1 /\(.*\)/ /90\1/ type national national
rule 2 /\(.*\)/ /900\1/ type international international
3)Translation rule to remove prefix 9 from the dialed number (sent by CUCM) as below
voice translation-rule 2
rule 3 /^9\(.*\)/ /\1/
4) Translation rule to ADD prefix 8136 or 8133 to calling number (sent by CUCM) as below
voice translation-rule 3
rule 1 /^6\(...\)$/ /8136\1/
rule 2 /^3\(...\)$/ /8133\1/
- Leave your translation profiles OutCalls and inboundcalls as below
voice translation-profile OutCalls
translate calling 3
translate called 2
voice translation-profile inboundcalls
translate calling 5
translate called 1
dial-peer voice 1 voip
description +++ INCOMING CALL FROM TELCO +++
translation-profile incoming inboundcalls
rtp payload-type cisco-codec-fax-ack 103
rtp payload-type nte 97
session protocol sipv2
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 2 voip
description +++ INCOMMING CALL FROM CUCM +++
incoming called-number 9T
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
dial-peer voice 110 voip
description +++ OUTGOING CALL TO TELCO +++
translation-profile outgoing OutCalls
destination-pattern 9T
session target ipv4:10.205.20.50
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 112 voip
description +++ Outgoing Direct Lines To UC +++
destination-pattern ....$
preference 0
session target ipv4:172.19.0.4
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 113 voip
description +++ Outgoing backup Lines To UC
preference 2
session target ipv4:172.19.0.5
voice-class codec 1
dtmf-relay rtp-nte
no vad
Related Information
