MGCP, H.323 and SIP on Same Gateway
3605
MGCP, H.323 and SIP on the same gateway
It is possible to have MGCP and H.323/SIP running on the same gateway at the same time, with some calls using MGCP and other calls using H.323 or SIP. MGCP is enabled per voice-port. Once configured, that port must always be under the control of MGCP. If there was a separate port without MGCP enabled, that port would route the calls using normal dial-peers with h323 or SIP. Calls that do not go through an MGCP-controlled voice-port can be treated as regular incoming CVP calls.
abbaswalikhan
Beginner
HI,
I have to configure an FXO on our MGCP gateway. This FXO will be used for the local site emergency calls to 999.
I have local dial-peers and the gateway turn to use them when its in the SRST mode but when the site is online
those dial-peers get ignored.
can you please give some example of how to configure so that everthing in MGCP but only that FXO uses H323 for 999 calls.
Abbas
Create
Recognize Your Peers
Content for Community-Ad
