MaryGrace
Symptoms
 When the user receive an incoming call user can only hear 3 beep sounds.
Diagnosis
 In this case the user’s inbound and outbound calls are working fine. However, when someone calls the user can only hear 3 beep sounds.
Solution
On CUCM navigate to Phone Configuration for Jabber. Uncheck Do Not Disturb and click Save. Advise the user to re-login to Jabber.
matt.tait
Worked fine.
I would say as well if you are looking to do this for a large number of users within the business, i would recommend using the bulk administration tool. Go to:
Bulk Administration -> Phones -> Update Phones -> Query
Once here select Find and Next (depending on if you want to affect all users)
Find the "Do Not Disturb" section and select the left box, leaving the right box unchecked. This ensures that you are changing all settings to have "Do Not Disturb" as off. The hit submit at the top of the page.
Once this is done you will be required to go to Job Scheduler found in: Bulk Administration -> Job Scheduler. You will then want to select the relevant job id and click "Activate Selected"
Thanks again for the help, and hope this extra guide has help others who have had this problem
MaryGrace
@matt.tait Thank you! This will be helpful in the future.
Tifytat
If only I could find the configuration
