vivekksi
Prerequisites
Requirements
Cisco recommends that you have knowledge of these topics:
  • SX80 codec
  • Precision 60 cameras
  • Speaker Track unit
  • High-Definition Multimedia Interface (HDMI) cables
  • RJ45 cables
Components Used
This document is not restricted to specific software and hardware versions.
The information in this document was created from the devices in a specific lab environment. All of the devices used in this document started with a cleared (default) configuration. If your network is live, make sure that you understand the potential impact of any command.
Configure
Note: Use the Command Lookup Tool (registered customers only) in order to obtain more information on the commands used in this section.
Diagrams
Cable Diagram of Speaker Track Connected to an SX80 Codec
Complete these steps in order to install the equipment:
  1. Configure the SX80 codec.
  2. Connect an RJ45 cable from the Network port 2,3 to the network port of the Speaker Track.
  3. Connect the HDMI cables from each camera to the HDMI Input port on the codec.
  4. Connect power to the Speaker Track.
  5. Connect an RJ45 cable from each camera to the respective network port on the Speaker Track.
  6. Connect power cables from each camera to the Speaker Track.
Enable the Speaker Track
When the cabling is complete, ensure that the Speaker Track configuration is set correctly.
xConfiguration Cameras SpeakerTrack ConnectorDetection CameraLeft: 1
Configuration Cameras SpeakerTrack ConnectorDetection CameraRight: 2
xConfiguration Cameras SpeakerTrack ConnectorDetection Mode: Auto
xConfiguration Cameras SpeakerTrack Mode: Auto
xConfiguration Cameras SpeakerTrack TrackingMode: Default
xCommand Cameras SpeakerTrack Activate
Verify
Use this section in order to confirm that your configuration works properly.
  • Codec - TC7.3.0
  • Speaker Track- MT7.3.0
  • Precision60- HC7.3.0
  1. Make sure the codec, Speaker Track, and camera use the same software version (numbers) suffix.
  2. Check the camera status and verify that the camera Serial number and Firmware are correctly detected.
    xstatus Camera
    *s Camera 1 HardwareID: "55000000"
    *s Camera 1 IpAddress: "169.254.1.43"
    *s Camera 1 MacAddress: "E4:C7:22:65:3F:D3"
    *s Camera 1 Manufacturer: "Cisco"
    *s Camera 1 Model: "Precision 60 Camera"
    *s Camera 1 Position Focus: 4200
    *s Camera 1 Position Pan: 3600
    *s Camera 1 Position Tilt: -650
    *s Camera 1 Position Zoom: 4128
    *s Camera 1 SerialNumber: "FTT181100R5"
    *s Camera 1 SoftwareID: "HC7.3.0.8cb420c, 2014-12-12"
    *s Camera 2 HardwareID: "55000000"
    *s Camera 2 IpAddress: "169.254.1.44"
    *s Camera 2 MacAddress: "E4:C7:22:65:3F:EE"
    *s Camera 2 Manufacturer: "Cisco"
    *s Camera 2 Model: "Precision 60 Camera"
    *s Camera 2 Position Focus: 0
    *s Camera 2 Position Pan: 3600
    *s Camera 2 Position Tilt: -650
    *s Camera 2 Position Zoom: 0
    *s Camera 2 SerialNumber: "FTT181100R1"
    *s Camera 2 SoftwareID: "HC7.3.0.8cb420c, 2014-12-12"
  3. Check the Speaker Track status in order to verify the availability and status.
    xstatus // speakerTrack
    *s Cameras SpeakerTrack Availability: Available
    *s Cameras SpeakerTrack LeftCamera VideoInputConnector: 1
    *s Cameras SpeakerTrack RightCamera VideoInputConnector: 2
    *s Cameras SpeakerTrack Status: Active
  4. Verify that the Speaker Track firmware is correctly detected.
    xstatus // Peripherals
    *s Peripherals ConnectedDevice 1045 Name: "SpeakerTrack 60"
    *s Peripherals ConnectedDevice 1045 SoftwareInfo: "MT7.3.0.8cb420c"
    *s Peripherals ConnectedDevice 1045 Status: Connected
    *s Peripherals ConnectedDevice 1045 Type: SpeakerTracker
Troubleshoot
This section provides information you can use in order to troubleshoot your configuration.
Verify the Speaker Track status in order to make sure the cabling is set correctly.
Here is a brief description of the previous output:
*s Cameras SpeakerTrack Availability can have one of these states:
  • Off
  • Unavailable
  • Available
Each of the states have a different meaning:
  • *s Cameras SpeakerTrack Availability: Off - this means that the Speaker Track option is turned off from the configuration.
  • *s Cameras SpeakerTrack Status: Unavailable - this means that the Control (Speaker Track/Camera) has an issue.
  • *s Cameras SpeakerTrack Availability: Available - this means that the control cabling is set correctly.
This status depicts the HDMI connection of the camera to the codec. The previous status is the expected output if the connection is correct .
If the HDMI cable from the Left camera is unplugged, the status changes to:
*s Cameras SpeakerTrack LeftCamera VideoInputConnector: 0
If the HDMI cable from the Right camera is unplugged, the status changes to:
*s Cameras SpeakerTrack RightCamera VideoInputConnector: 0
This might cause the Speaker Track to not function.
*s Cameras SpeakerTrack Status: Inactive
The user has selected Manual Tracking and Auto Tracking has been disabled from the Touch Panel. This can be enabled with the xCommand Cameras SpeakerTrack Activate command.
Diagnostics
In order to verify the functionality of the face detection mechanism, enter this command to start the Active speaker and face detection:
xCommand Experimental SpeakerTrack Diagnostics Start Tracking: On
Logs
View these logs at the time of Speaker Track installation.
Endpoint captures the below logs at the time of the Camera and Speaker Track Pairing:
15342.61 CAMERA I: PairingStatus Starting: 1 Paired: 1 Connected: 1
15342.61 CAMERA I: PairingStatus MacAddr: 'E4:C7:22:65:3F:D3'
 Ipv4: '' Ipv6: '' Ipv6Global: 'fe80::e6c7:22ff:fe65:3fd3'
15342.78 CAMERA I: PairingStatus Starting: 1 Paired: 1 Connected: 1
15342.79 CAMERA I: PairingStatus MacAddr: 'E4:C7:22:65:3F:EE'
 Ipv4: '' Ipv6: '' Ipv6Global: 'fe80::e6c7:22ff:fe65:3fee'
15342.81 SpeakerTrack I: Peripheral C0:67:AF:58:B8:2D does not need SW upgrade
15342.90 CAMERA I: PairingStatus Starting: 0 Paired: 1 Connected: 1
15342.90 CAMERA I: PairingStatus MacAddr: 'E4:C7:22:65:3F:D3'
The connected status shows that the Speaker Track is successfully installed.
External Link: http://www.cisco.com/c/en/us/support/docs/collaboration-endpoints/telepresence-speakertrack-60/118733-config-speaker-00.html
10 Comments
MD KAFINUZZAMAN
Thanks for your post
can you help me. I can't find any exact document to configuration SX80 using GUI mode.When I call SX80 to SX20 its show call failed. Should I use sip or h323 protocol.
I need a good document.
kafi
vivekksi
Do you still require the document, because this information is available on admin guide, please let me know if you require more detailed information for the same.
Hi Vivek,
Excellent his explanation, but still do not understand how physically install the Speaker Track fits on top of the display or to be fixed on the wall?
Tks
Carlos
vivekksi
Hi Carlos,
Thanks, you can refer following document for the physical installation.
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/camera/precisionhd/installation_guide/speakertrack-60-installation-guide.pdf
Hi Vivek,
But i have other question.I can leave this Speaker Tracker on a table, because the manual only mentions the installation on a wall. I can leave it as is shown in the video, on a flat surface?
Tks,
Carlos
vivekksi
Hey Carlos,
It's fine you can put in flat table and it will work fine, you can deploy or install speaker track as per your need.
Vivek
Aman Soi
Hi Vivek,
[+5]
We have got Cisco SX80 Codec with one Precision 60 camera and Touch Panel connected to SX.
Is there any way we can assign IP address to Camera and Touch Panel?
regds,
aman
vivekksi
Hi Aman,
I wanted to confirm is there any specific reason why you want to assign IP address as codec provide IP address directly to this device from 169.x.x.x
Vivek
Aman Soi
Hi Vivek,
thanks for reply.
this was the query asked by the customer .The way we can get GUI to SX80 so, the same should be working for Touch and Camera when LAN cable is connected.
So, we wanted to assign static IP to Camera and Touch.
regds,
aman
rajbhatia
Hello. Thanks for this. We've installed an SX80 with speaker track some time back and noticed one of the cameras showing as disconnected from the codec. The installer (site is remote) went out and rebooted (hard reset) the codec since all the cabling looked ok and the cameras were back on line.
The problem now is that during a call that lasts longer than 30 minutes, the cameras on the SX80 got to sleep and revert to the off position - this is assuming nobody from that site speaks or has the mic on mute. This did not occur before. Any ideas on how to fix this to make sure the cameras always stay "on" during a call?
Thanks.
