Tech Note: Securing Cisco Unified CME and IP Phones
2191
Introduction
This document covers some of the best practices methodologies you should put into operation to secure and prevent Toll fraud on Cisco Unified Communications Manager Express and the IP Phones connected to the network.
How to secure Cisco Unified CME and IP Phones?
  • After-hours calling Restrictions
  • Call Transfer Restrictions
  • Call Forward Restrictions
  • Class of Restrictions (COR)
  • Securing GUI access on CME
  • Strict ephone Registration
  • Deny external traffic on Voice signaling ports
  • Disable ephone Auto-registration
Configuration examples are based on Cisco Unified CME Version 8.6.
1. After-hours Calling Restrictions
Cisco Unified CME enables you to configure toll restriction policies based on time and date. You can configure the calling policies so that the users are not allowed to make calls to predefined numbers during certain hours of the day and outside business hours.
Sample configuration
CME1(config)# telephony-service
CME1(config-telephony)#  after-hours day Mon 20:00 08:00
CME1(config-telephony)#  after-hours day Tue 20:00 08:00
CME1(config-telephony)#  after-hours day Wed 20:00 08:00
CME1(config-telephony)#  after-hours day Thu 20:00 08:00
CME1(config-telephony)#  after-hours day Fri    20:00 08:00
CME1(config-telephony)#  after-hours day Sat   12:00 12:00
CME1(config-telephony)#  after-hours day Sun 12:00 12:00
Blocks calls outside of business hours, Monday to Friday before 8 am and after 8 pm.
CME1(config-telephony)#  after-hours block pattern 1 91900 7-24
CME1(config-telephony)#  after-hours block pattern 2 91
CME1(config-telephony)#  after-hours block pattern 3 9011
Calls to premium numbers, say 900 numbers are blocked all the time irrespective of the day.
2. Call Transfer Restrictions
Call transfer to VOIP or POTS ie PSTN numbers can be allowed explicitly but this may open doors for toll fraud. You can use the call transfer restriction to secure the CME.
CME1(config-telephony) # transfer-pattern 91919.......$
This limits the call transfer to numbers in area code 919 and bar transfers to any other numbers.
CME1(config)# ephone-template 1
CME1(config-ephone-template)# transfer-pattern blocked
This command disables the call transfer to any destination POTS or VOIP.
CME1(config)# ephone-template 2
CME1(config-ephone-template)#  transfer max-length 4
This command specifies the maximum number of digits a user can dial when a call is transferred.
CME1(config)# ephone 10
CME1(config-ephone)# ephone-template 1
CME1(config)# ephone  20
CME1(config-ephone)# ephone-template 2
3. Call Forward Restrictions
For an attacker, the most convenient way to exploit a phone system for toll fraud is to have an insider do a call-forward to certain destinations. To restrict the number of digits that can be dialed by CME, you can use the call forward restriction feature.
CME1(config)# ephone-dn 60
CME1(config-ephone-dn)# number 5001
CME1(config-ephone-dn)# no forward local-calls
This feature restricts the call forward to local calls
CME1(config)# ephone-dn-template 10
CME1(config-ephone-template)# call-forward max-length 4
This restricts the number of digits that can be dialed by CME during Call forward.
4. Class of Restrictions (COR)
Class of Restriction (COR) in CME is identical to voice gateways. You can apply the COR list in ephone-dn in addition to dial-peers.
CME1(config)# ephone-dn 10
CME1(config-ephone-dn)# number 1001
CME1(config-ephone-dn)# cor incoming internal
CME1(config-ephone-dn)# cor outgoing local
5. Securing GUI access on CME
SSL for HTTP (HTTPS) provides server authentication, encryption and message integrity to allow secure HTTP communications. SSL also provides HTTP client authentication. It is highly recommended to have Cisco Unified CME GUI interface secured with HTTPS access.
CME1(config)# crypto key generate rsa exportable label httpkeys usage-keys 1024
CME1(config)# ip http server
CME1(config)# ip http secure-server
CME1(config)# ip http secure-port <port-number>
CME1(config)# ip http authentication AAA | TACACS | local
Default HTTPS port is 443, which can be changed to a higher port (none-1024) port number.
5. Strict ephone Registration
CME should be configured to enable only Cisco Unified IP Phones in the trusted domain (inside zone) for registration. You can use the strict-match option in ip source-address command so that only locally attached IP Phones can get register to CME.
CME1(config-telephony)# ip source-address 10.85.102.160 port <2000/5060> strict-match
In addition block TCP ports 2000-2002 and 5060 from the WAN to prevent external SCCP/SIP phone registration with CME.
6. Deny External Traffic on Voice signaling ports
CME1(config)# ip access-list extended BlockTraffic
CME1(config-ext-nac1) deny tcp any any range 2000 2002
CME1(config-ext-nac1) deny tcp any any eq 5060
CME1(config-ext-nac1) permit ip any any log
CME1(config)# interface FastEtherner 1/0
CME1(config-if)# ip access-group BlockTraffic in
7. Disable ephone Auto-Registration
CME enables auto-registration of ephones by default. This implies that new Cisco Unified IP Phones that try to register with CME are auto-registered with DN auto-assigned and are able to make calls immediately. You can disable auto-registration to prevent toll fraud.
CME1(config-telephony)# no auto-reg-ephone
Restricting SIP Phone Auto Registration : For SIP Phones you must configure the system so that the SIP endpoints must authenticate with a username and password
CME1(config)# voice register global
CME1(config-register-global)# mode cme
CME1(config-register-global)# source-address 10.85.102.152 port 5060
CME1(config-register-global)# authenticate register
Related Information
Collaborator
Nice Examples...
Content for Community-Ad
August's Community Spotlight Awards
