UCCX 8.x - a Really Simple SOAP Client (no custom JAR)
20914
Problem: it's a common task for a call center routing script to communicate with a remote procedure using the SOAP protocol, over HTTP. Usually, the script sends a piece of information to the SOAP server, parses the response, reads some useful data and then continues.
Analysis: Unfortunately, there is no built in step or method to create a simple SOAP client within a CRS script (and I don't blame the UCCX programmers for that). Some people use various frameworks (JAX-WS, Axis) to make SOAP calls easier, this usually requires an IDE like NetBeans or Eclipse, building a Java package, and uploading it - along with the framework itself - as custom JARs to the UCCX server. Personally, I don't really like that idea:
  • it makes debugging complicated;
  • if any change is needed, one must rebuild the whole solution, upload it to the UCCX server, restart the CCX engine - who likes this hassle;
  • I don't see the reason why we can't keep things simple and stupid - meaning, CRS scripts can do Java, and Java (at least Java 6 which comes with UCCX 8.x) can do everything you need to build a Really Simple SOAP Client.
UPDATE 1: if you are interested in a more OOP-style WS client (created with JAX-WS) read the following post:
https://supportforums.cisco.com/docs/DOC-26957.
UPDATE 2: I got a couple of comments and private messages about the CCX editor not accepting the second Set step due to one line:
return new String(baos.toByteArray());
This is a bug in some versions of UCCX. Unfortunately, for some reason it will sort of "hide" the Set step if it contains the above line. I don't know why it won't allow calling the toByteArray() method on a ByteArrayOutputStream object, this method is legal. Some versions of UCCX may accept it, some just won't. For instance, UCCX 8.0.2 happily accepts that method, UCCX 7.0SR5 does not.
If your UCCX is affected by the bug, then try replacing the above line with the following:
return baos.toString();
This has been tested and found working with UCCX Premium 7.0SR5 which does contain the bug, so the Set step disapperared with the original line but it did not with the replacement.
Solution: so, what is SOAP anyway?
In Plain English, it consists of:
  1. creating an XML document;
  2. SOAP Request: sending this XML document to the SOAP server. This is usually HTTP POSTing it to the web server;
  3. read the SOAP response (this is an XML document, too);
  4. parse the SOAP response and filter out the information we are looking for.
Looking at the tools the CCX editor offers for the above four tasks:
1. creating an XML document - easy. Two alternatives:
  • XML Template: you can upload an XML document on to the UCCX server, with some tokens; then, using the Keyword Transform Document step (where the already existing XML document will be the template), just replace the tokens with the desired values. That works just great if you don't want anything complicated and you are absolutely sure the result will also be a valid XML document (so there is no chance the Keyword Transform Document messes it up with some unexpected characters etc).
  • You can, of course, use Java to build the XML from scratch if you want to have more control. Personally, I like this option.
2. sending this XML document - now, one may say, there's the Create URL Document step, and it can do HTTP Post. Well, that's right, the step exists, it can sort of POST, but it's not the POST we are looking for. This step actually formats the value to be sent differently (application/x-www-form-urlencoded) which may or may not be accepted by the SOAP server. Java gives you more precise tools for that.
3. reading the SOAP response - this actually goes along with the previous step. But if we send something unacceptable to the SOAP server, we cannot expect a valid response either. Using Java gives you more granulated control.
4. parse the SOAP response and "fish out" the desired piece of information - easy. The Get XML Document Data step can operate with XPath expressions perfectly. So no Java code is needed.
**** DISCLAIMER: This is a proof of concept. I am not responsible for any damage, including the death of your favorite pet/rockstar. I cannot guarrantee this solution is the best, I cannot even guarrantee it would work in your system. Tested with IP IVR version 8.0(2) ****
I am going to explain the whole process using an example. Again, y u no build any packages, custom JARs. I don't even expect you to be fluent in Java.
In our not at all imaginary call center, there's a UCCX script that is supposed to do some routing decision based on a number which is calculated by some legacy systems, which speak SOAP only.
The expected SOAP request:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
   <soapenv:Header/>
   <soapenv:Body>
      <mis:GetCallAggregates xmlns:mis="http://mis.report.pointers.cz/">
         <startDate>2012-04-01T00:00:00</startDate>
         <endDate>2012-04-02T23:59:59</endDate>
      </mis:GetCallAggregates>
   </soapenv:Body>
</soapenv:Envelope>
If everything goes fine, then the SOAP response is:
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
   <soap:Body>
      <ns2:GetCallAggregatesResponse xmlns:ns2="http://mis.report.pointers.cz/">
         <GetCallAggregatesResult>
            <CallAggregate>
               <date>2012-04-01T00:00:00+02:00</date>
               <parameterName>AbandonIn30</parameterName>
               <value>12.0</value>
            </CallAggregate>
            <CallAggregate>
               <date>2012-04-02T00:00:00+02:00</date>
               <value>125.0</value>
            </CallAggregate>
            <CallAggregate>
               <parameterName>BehindIVR</parameterName>
               <value>665.0</value>
            </CallAggregate>
            <CallAggregate>
               <value>5476.0</value>
            </CallAggregate>
            <!-- omitted for brevity -->
         </GetCallAggregatesResult>
      </ns2:GetCallAggregatesResponse>
   </soap:Body>
</soap:Envelope>
If we send something to the SOAP server and an error occurs, the SOAP response looks like this (I just inserted a bogus <boo> tag into the XML):
   <soap:Body>
      <soap:Fault>
         <faultcode>soap:Client</faultcode>
         <faultstring>Unmarshalling Error: unexpected element (uri:"", local:"boo"). Expected elements are (none)</faultstring>
      </soap:Fault>
   </soap:Body>
</soap:Envelope>
Now, take a look at the request again:
   <soapenv:Header/>
   <soapenv:Body>
   </soapenv:Body>
</soapenv:Envelope>
As we can see, it's just a plain ordinary XML document (sans the XML declaration, for the sake of brevity). The so-called root element is soapenv:Envelope (its namespace in red, first row - expected by the SOAP server). The first child node is soapenv:Header; notice, it is empty - my SOAP server does not expect any headers. Then the soapenv:Body - this contains the next element, mis:GetCallAggregates (with the namespace URI in red, again), and this contains two elements, startDate and endDate (each containing a date and time string).
In other words, I am asking the SOAP server to run the GetCallAggregates method, with two parameters, startDate (its value is 2012-04-01T00:00:00) and endDate (its value is 2012-04-02T23:59:59). Actually, I am asking for some statistical information (CallAggregates) within the specified dates (1st April 2012 00:00:00, and 2nd April 2012 23:59:59).
This can be very easily constructed in Java, using only the tools Java 6 offers. And, as we know, Java 6 - more precisely, JDK 1.6 - is included in UCCX and if you have IP IVR or UCCX Enhanced or Premium, you can use it, most likely with Set steps.
Constructing XML in Java
First, I am going to create a new variable, type String, and name it soapRequest (initial value: null).
Then I am going to insert a Set step into my script, that would yield the value of the above soapRequest variable. The value field would be a closure (a block of Java code. Don't panic, I'll explain that, too!)
The source code I am using at this step (please note: // starts a line of comment):
// first, create a new buffer:
java.io.StringWriter buffer = new java.io.StringWriter();
// define namespace URI's and prefixes
// (take a look at the SOAP request XML above, you'll see there are two namespace prefix - URI pairs
final String SOAPENV_NAMESPACE_URI = "http://schemas.xmlsoap.org/soap/envelope/";
final String SOAPENV_NAMESPACE_PREFIX = "soapenv";
final String MIS_NAMESPACE_URI = "http://mis.report.pointers.cz/";
final String MIS_NAMESPACE_PREFIX = "mis";
// some of the following methods may throw an exception (~ error), so we want to wrap them
// into a try..catch block. Remember, if an exception occurs, the resulting value,
// thus the soapRequest variable will be null
        try {
// create a document builder "factory" (that builds the document)
// make it namespace aware
// then crate a new document
        javax.xml.parsers.DocumentBuilderFactory factory = javax.xml.parsers.DocumentBuilderFactory.newInstance();
        factory.setNamespaceAware(true);
        javax.xml.parsers.DocumentBuilder documentBuilder = factory.newDocumentBuilder();
        org.w3c.dom.Document document = documentBuilder.newDocument();
// insert the "root" element (soapenv:Envelope), and introduce the required namespace:
        org.w3c.dom.Element root = document.createElementNS(SOAPENV_NAMESPACE_URI, SOAPENV_NAMESPACE_PREFIX + ":Envelope");
        root.setAttributeNS("http://www.w3.org/2000/xmlns/", "xmlns:" + SOAPENV_NAMESPACE_PREFIX, SOAPENV_NAMESPACE_URI);
// create the header element (precisely: soapenv:Header)
// we are going to append it to the root element right away (since it should not contain anything)
        org.w3c.dom.Element header = document.createElement("soapenv:Header");
        root.appendChild(header);
// create the body (precisely: soapenv:Body) element:
        org.w3c.dom.Element body = document.createElement("soapenv:Body");
// create another element, mis:GetCallAggregates, now with a different namespace, too:
        org.w3c.dom.Element gca = document.createElementNS(MIS_NAMESPACE_URI, MIS_NAMESPACE_PREFIX + ":GetCallAggregates");
        gca.setAttributeNS("http://www.w3.org/2000/xmlns/", "xmlns:" + MIS_NAMESPACE_PREFIX, MIS_NAMESPACE_URI);
// and, create two other elements, startDate and endDate
// each contains a date-time string:
        org.w3c.dom.Element startDate = document.createElement("startDate");
        startDate.setTextContent("2012-04-01T00:00:00");
        org.w3c.dom.Element endDate = document.createElement("endDate");
        endDate.setTextContent("2012-04-02T23:59:59");
// adding startDate and endDate to mis:GetCallAggregates
        gca.appendChild(startDate);
        gca.appendChild(endDate);
// adding mis:GetCallAggregates to the soapenv:Body element
        body.appendChild(gca);
// adding the soapenv:Body element to the root element (soapenv:Envelope)
        root.appendChild(body);
// and then adding the root element to the document
        document.appendChild(root);
// at this point, we've got the programmatic representation of XML
// but we need to transform it into a String so we can send it to the SOAP server
// this can be achieved, too: the source being the programmatic representation
// and the result is the buffer we specified on the first line
        javax.xml.transform.TransformerFactory transFactory = javax.xml.transform.TransformerFactory.newInstance();
        javax.xml.transform.Transformer transformer = transFactory.newTransformer();
        javax.xml.transform.Source source = new javax.xml.transform.dom.DOMSource(document);
        javax.xml.transform.stream.StreamResult result = new javax.xml.transform.stream.StreamResult(buffer);
        transformer.transform(source, result);
        } catch (Exception e) {
// again, if anything happens,the strack trace is sent to the standard output (stdout.log, most likely)
            e.printStackTrace();
// and then null is returned
            return null;
        } // try..catch block ends here
// but if there are no problems, the buffer is cast into a String:
return buffer.toString();
} //closure ends here
I know, it might be overwhelming, but once you understand the basic concepts of XML, this code will also be easier to read.
So at this point, we've got the SOAP request XML document - held by the soapRequest variable.
Issuing the SOAP request, using Java
Again, we need to connect to the web server, in other words, to the endpoint, and using HTTP POST, send the XML document created above.
First, I am going to introduce three new variables:
soapResponseString, type String, initial value: null
soapResponseDoc, type Document, initial value: DOC[]
soapServiceEndpoint, type String, initial value is "http://10.232.108.15:8080/MIS/services/MISReport"
Just some more details on them: soapResponseString is the raw "string", sent by the SOAP server as response. Since the Get XML Document Data step can only operate on documents of which type is Document, we'll have to use a different variable, with the expected type, soapResponseDoc. And, as you might have guessed, the soapServiceEndpoint contains the URL of the SOAP Server endpoint.
Then, the Set step. The variable is the soapResponseString, and the value field contains another nice block of code again:
Source code (again, don't panic!):
// create a ByteArrayOutputStream - this is actually a buffer
// we are going to use to store the response coming from the SOAP server
java.io.ByteArrayOutputStream baos = new java.io.ByteArrayOutputStream();
// this is quite unnecessary: assigning the value of the soapRequest (still holding our XML document)
// to another variable, named content, type String; but anyway, it's just cleaner
String content = soapRequest;
// specify a timeout - 5000 milliseconds - if the web server does not start sending back
// anything within this timeframe, an exception will be raised
int readTimeout = 5000;
// now, the following methods are enclosed by a try..catch block
// to catch any exceptions - we just want to have control over them
// remember, an uncaught exception might stop your CRS script execution
// and you might not want that
try {
// a new URL, which is the soapServiceEndpoint variable value (http://ip:port/ etc):
     java.net.URL url = new java.net.URL(soapServiceEndpoint);
// creating a HTTP connection to the above URL:
     java.net.HttpURLConnection urlCon = (java.net.HttpURLConnection) url.openConnection();
// setting some important header parameters, first of all, content length, this is most likely expected
// by the SOAP server
     urlCon.setFixedLengthStreamingMode(content.length());
// setting the timeout:
     urlCon.setReadTimeout(readTimeout);
// we tell Java we will do input (in other words, we will read):
     urlCon.setDoInput (true);
// we tell Java we will do output (in other words, we will send):
     urlCon.setDoOutput (true);
// we tell Java not to cache:
     urlCon.setUseCaches (false);
// we are using HTTP POST
     urlCon.setRequestMethod("POST");
// finally, we set the Content-Type header,
// this way we are telling the SOAP server we are sending an XML, using the UTF-8 charset
     urlCon.setRequestProperty("Content-Type","text/xml;charset=UTF-8");
// opening an OutputStream (this is a one-way channel towards the SOAP server:
     java.io.DataOutputStream output = new java.io.DataOutputStream(urlCon.getOutputStream());
// we write the contents of the content variable (= soapRequest = XML document):
     output.writeBytes(content);
// telling Java to flush "speed up!" and then close the stream:
     output.flush();
     output.close();
// now getting the InputStream (getting a one way channel coming from the SOAP server):
     java.io.DataInputStream input = new java.io.DataInputStream(urlCon.getInputStream());
// buffered read from the InputStream, buffer size 4Kilobytes (= 4096 bytes):
// and the buffer is always written to the other buffer, named baos, that we specified
// on the first line of this block of code
     int bufSize = 4096; // buffer size, bytes
     byte[] bytesRead = new byte[bufSize];
     int bytesReadLength = 0;
     while(( bytesReadLength = input.read( bytesRead )) > 0 ) {
         baos.write(bytesRead,0,bytesReadLength);
     } //while block ends here
// closing the InputStream:
     input.close();
// closing the baos buffer
     baos.close();
// again, if an error occurs, let's just send the stack trace to stdout (stdout.log)
// and then return null
    return null;
// construct a new String, and return that to the CRS script:
} // closure ends here
(N.B.: If your UCCX is affected by a strange bug - see UPDATE 2 - try replacing
with
There's still one more step, cast this soapResponseString to a Document. Notice the next step, the Get XML Document Data step expects the document be created by the Create XML Document step. But that's not a problem:
Voilá, we've got our SOAP response document. Again, it's something like this if everything goes perfectly:
   <soap:Body>
            <CallAggregate>
               <value>12.0</value>
            </CallAggregate>
            <CallAggregate>
            </CallAggregate>
            <CallAggregate>
            </CallAggregate>
            <CallAggregate>
            </CallAggregate>
   </soap:Body>
</soap:Envelope>
And like this if something goes bad:
   <soap:Body>
      <soap:Fault>
      </soap:Fault>
   </soap:Body>
</soap:Envelope>
Getting the desired value from the SOAP response XML document
For now, let's pretend everything went fine, there were no errors. I am interested in the value of the "value" element of the first CallAggregate element (where the date is 2012-04-01 and the "parameterName" is AbandonIn30):
We use the Get XML Document Data step for it (the result variable is named inString, type String, inital value: null):
The actual XPath expression:
"//CallAggregate[1]/value"
Of course, you might check whether there are any soap:Fault nodes, you can do that using the XPath expression //faultcode (for instance).
Check Wikipedia or w3schools for more XPath examples.
Conclusion: this is a simplistic approach, yet it works very well in a real environment.
Happy coding!
Advocate
glad to hear that.
Actually, XPath (Get XML Document Data) can be really tricky sometimes, if you get stuck, just post the XML returned by the WS server and we can look at it together.
G.
Still haven't been able to grap the PIN value out...
This is the XML response after the CreateXMLDocument step...
TEXT[<?xml version=\"1.0\" encoding=\"UTF-8\"?>\r\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\"><s:Header><ActivityId CorrelationId=\"6d77e586-3847-4573-9595-30e7e94eed03\" xmlns=\"http://schemas.microsoft.com/2004/09/ServiceModel/Diagnostics\">69958924-f8a0-4195-8399-6a843c113edd</ActivityId></s:Header><s:Body><CreatePinResponse xmlns=\"http://tempuri.org/\"><CreatePinResult>075869</CreatePinResult></CreatePinResponse></s:Body></s:Envelope>]
After this i run the Get XML Doc Data step with an XPATH expression like
PIN = Get XML DocumentData (soapCreatePinDocument, "XPATH") with:
"/Envelope/Body/CreatePinResponse/CreatePinResult/" OR
"//CreatePinResponse/CreatePinResult/"
but neither of these worked... I tried using the descendant/child params but still the same...
Will try to brush up on XPATH on w3c today and try again with this tommorow.
Kenan.
Advocate
yes, XPath chokes on the namespace (in this case, s).
Can you try this:
//*[local-name()='CreatePinResult']/text()
G.
Hi.
Thanks again G. I just removed "text()" at the end and it works like a charm.
Where can i FedEx you a beer?
I'm guesing somewhere in Romania by your surname...
Advocate
Miss. It's Prague, Czech Republic (at this moment).
I really appreciate your offer but since I am in Prague, sending beer here would be like importing cheese to France
Anyway, I am glad it works. Actually, the method text() is appended automatically within a UCCX script, at least I guess, based on this behaviour, but "real", "canonical" XPath expects it. You cannot just write //something because it would return an XML element, not a String.
Happy coding.
G.
Beginner
Greg, this is really great manual I really need to satisfy requests at Customers'.
Thanks.
Community Member
Hi Gergely,
i tried your code. but i am getting an error.
"unable to parse expression;invalid identifier:java".
I put e set node and tried to set the value through expression editor. but i got the above error.
whether i need to import anything or need to do any other additional configuration to use the above code.
Please help
Enthusiast
Hello and thanks for this great document!
I used this and created code to send AXL SOAP requests to Cisco CUCM. Unfortunately CUCM only accepts HTTPS for AXL connections. At the moment the request are not send because of the unknown certificate of the CUCM.
Adding the certificats in the OS Administration doesn't seem to make any difference.
Is there a way to add certificates to the java certificate store on UCCX?
Bernhard
Hello Bernhard.
I had a similar problem with uccx 8.0, and the SSL Handshake Exception was thrown.
The issue was fixed when I opened a TAC and an engineer imported all of the Web Service's certificates of my customer.
When I used the uccx 8.5 this same issue was not detected. The SSL Handshake between the Customer's WS and UCCX happened automatically.
I hope to have helped you.
Valber Carvalho.
Enthusiast
Turned out I hit bug CSCue13884.
Had to raise a tac case to import our root certificate to the java keystore.
It's working now!
Beginner
Hi Gergely,
I am following your java code example, but I have some problem, first part (create xml document) adds strange symbols to it, could do you help me ?
CCX version: 8.5.1.11004-25
Advocate
Hi, sure. May I ask you to post your question under the Discussions section for better visibility. Thanks. G.
Contributor
I know this post has been around for a while, but hoping that someone who has written this into UCCX Script Editor would be willing to post a sample script here for others to review.
Hi jsteinberg,
I had shared with the community an example three years ago.
Go to: https://supportforums.cisco.com/discussion/11279331/how-using-custom-java-class-uccx-5x-soap-example
Following this Gergely's steps you will have sucess in your implementation, but you need to be prepared to understand Java Code and Soap 1.x.
It's not easy.
Good Luck!
Valber Carvalho
Beginner
Hello!
I do not fully understand the process you've described, if I put the skriptet here you can look at?
