Unity connection 9.1(1)-Unable to create more than 8 ports
6002
CUC 9.1(1)-Unable to create more than 8 ports for 4 GB RAM,1 vCPU
Symptoms
Unable to add more than 8 ports while doing Telephony integration in Unity Connection (defect CSCud86448 )
Version affected - 9.1.1.10000-11
                            9.1.1.20000-5
This Issue is seen only in Unity connection installed on Virtual Machine with 1 vCPU and 4 GB RAM.
Cause / Problem Description
Enhancement was implemented to provided 8 port support for connection with 2.5 GB  RAM , but after this enhancement it was detected that for 4 GB Ram  system is allocating only 8 Ports .
Resolution
Defect CSCud86448 was fixed which did not make into the public releases
Hence Install the "ciscocm.cuc_license_patch.sgn" COP file.
This update must be installed on all machines in the cluster; cluster/stand-alone reboot is not required
COP file download
Readme
http://www.cisco.com/web/software/282204704/18582/Readmeforciscocm.cuc_license_patchCOPfile.pdf
Note: From Unity connection 9.x onwards , we don’t license ports via the License files and instead the number of ports that we can create is based on the hardware we install the server
You can check the number of ports supported for different platform here
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/supported_platforms/9xcucspl.html#wp810181
10 Comments
Collaborator
Hello im using the version 9.1.1.20000-32 and i applied the file ciscocm.cuc_license_patch.sgn and now the problem is solved.
I think its important to add the version 9.1.1.20000-32 in the version affected.
Leonardo Santana
Hi Leonardo,
Version 9.1.1.20000-5 and 9.1.1.20000-32 is same .
9.1.1.20000-5 is the Platform version and 9.1.1.20000-32 is Unity specific .
You can see from the following commands ...
admin:show version active
Active Master Version: 9.1.1.20000-5
admin:show cuc version
Active version: 9.1.1.20000-32
Beginner
Cannot install Locale after COP file installation.
Has anyone gor this issue? After file got uploaded, Screen goes Blank and I cannot press Next to continue.
Install via CLI "utils system upgrade initiate"
Beginner
Good one!
Thanks, I had the same problem and I am resolved!
Beginner
The URL provided above for the COP file download isn't available anymore.
Facing this issue on both UCS and SRE module. Any suggestions?
Hi ,
Which version of Unity Connection are you running ?
Beginner
Hi Mahesh,
We have installed 9.1.1.20000-5 on both UCS and SRE module.
Sami
I have updated the link.
http://software.cisco.com/download/release.html?mdfid=284603371&flowid=45680&softwareid=282204704&release=COP-Files&relind=AVAILABLE&rellifecycle=&reltype=latest
Recommendation would be to upgrade to 9.1(2)SU2a if this is a new installation
