This document will help you upgrade the TC series codecs using WinSCP. If you have any additions to be done on this document, please let me know.
Mubashshir Akhtar
TelePresence Support Team
Thank you Mubashshir, this is exactly what I was looking for.
Hey Mubashshir,
How is this procedure affected by the TC7+ code now that root access has been removed? Does the temporary privileged account that would have to be obtained through TAC give us the right to SCP files across to CODEC?
I have a user where this might be the only may to update their CODECs and obtaining temporary privileged accounts for each CODEC, every time we want to upgrade is going to be a pain.
Chris
Chris -
You'll need to contact TAC and get the password to login with the remotesupport account to use WinSCP with the codec unfortunately.
Regarding WinSCP, it's mentioned in the below discussion, Mangus' comment about uploading of software to the codec, Wayne later replies and acknowledged that this method works:
Upload the package to the /tmp folder (remotesupport has write access here) and log in as the remotesupport user. Then run the command: sudo installimage <package name>
https://supportforums.cisco.com/discussion/12166996/tc71-now-released-and-available-ciscocom
I tried the method described with a C20 TC6.2 and loading the s52000tc7_3_2 pkg, but the automatic extract did not start. Tried a restart and reboot still no update. The rights are rw-r--r-- owner root. There is also an upload directory under the upgrade directory. Any idea what may be the issue?
[@joel.stanfield] - for you, or anyone else who stumbles on this (like I did), you can do the following:
NPM
