Walkthrough Wednesdays
Webrtc demo system
7557
Gonzalo Gasca Meza
Beginner
The following document will help you connect your Web Browser to an existing Video or Audio System. This demo describes the steps needed to connect a WebRTC capable Web Browser, (Google Chrome, Google Chrome Canary, FireFox, FireFox Nightly) to an existing Audio and Video system (Cisco TelePresence Server, McuWeb, Cisco Codian MCU.)
The components used in this demo are:
  • Google Chrome Canary
  • Telestax (WebSockets application)
  • Telestax Sip Servlet (Opencall B2BUA)
  • Doubango sipML5 client (customized)
  • Doubango webrtc2sip (Media converter VP8 to H.264)
Components
Version
33 canary
Mobicents
mss-2.0.0.FINAL-jboss-as-7.1.2.Final
Opencall sip servlet B2BUA
opencall-1.1.0-BELADOR
WebSockets sip servlet
websockets-sip-servlet-2.1.0-20121108.113957-1
Doubango   webrtc2sip
webrtc2sip 2.6.0
Doubango   sipML5
sipML5   Doubango version 203
Architecture
By using Doubango SipML5 we utilize HTML5 SIP client entirely written in JavaScript. The client is used to connect to any SIP or IMS network from WebRTC-capable browser to make and receive audio/video calls. This SIP client registers to Telestax WebSockets Sip Servlet via WebSockets protocol that runs on top of Mobicents Server. For more information please review TeleStax:
https://code.google.com/p/sipservlets/wiki/HTML5WebRTCVideoApplication
Usage
In order to dial from your web browser you have two options:
  • Utilize pre-defined parameters (Demo system)
  • Configure your own parameters and dial to any public or local SIP URI
No need to deploy any component, you will be using pre-deployed systems in Amazon AWS.
1) Access:
http://webrtc.ramennetworks.com/
2) Configure parameters
Parameter
Description
Recommended value
Display   Name:
Caller Name
Chrome
Private   Identity*:
Calling number
+14082221000
Public   Identity*:
From URI
sip:+14082221000@opencall.org
Enable Interop
Enable H.264 support
Enable
This modified HTML page is already configured to use Amazon AWS servers. You can enable Developer mode JavaScript console view in Web Browser to see values.
sipRegister() (index):353
s_websocket_server_url=ws://webrtc2sip.ramennetworks.com:5062 tsk_utils.js?svn=20:116
s_sip_outboundproxy_url=tcp://172.31.46.56:5060 tsk_utils.js?svn=20:116
b_rtcweb_breaker_enabled=yes
3) Login
4) Dial number
You can use any valid SIP URI. Example:  22223333@videolab.att.com,testcall@video.att.com
Configure your own parameters and servers and dial to any public or local SIP URI
Access via HTTP the following page:
http://sipml5.org/index.html
From there click on Enjoy our live demo.
Parameter
Description
Recommended value
Display   Name:
Caller Name
Chrome
Private   Identity*:
Calling number
+14082221000
Public   Identity*:
From URI
Password:
Password
14082221000
Realm*:
Domain
172.31.46.56
If you want to enable H.264 codec you need to go to expert mode and enter the following:
Parameter
Description
Recommended value
Enable RTCWeb Breaker
Enables webrtc2sip utilization
Enabled
WebSocket Server URL
webrtc2sip server
SIP outbound Proxy URL
mobicents websockets sip servlet
Deploying
The following table describes the steps necessary steps to deploy this system:
ComponentsDeployments steps
Google Chrome CanaryInstall
MobicentsDownload, Install, Configure
OpencallDownload, Configure, Deploy
WebSockets   Sip ServletDownload,   Deploy
Doubango webrtc2sipDownload, Install, Configure
Doubango   sipML5Configure
Installation
Google Chrome installation
  • Download and Install Google Chrome
https://www.google.com/intl/en/chrome/browser/
Mobicents installation
  • Download Mobicents 2.0 Jboss
http://sourceforge.net/projects/mobicents/files/Mobicents%20Sip%20Servlets/
  • Extract Mobicents file
mss-2.0.0.FINAL-jboss-as-7.1.2.Final-1349104459.zip
  • Download configuration file standalone-sip.xml
http://github.com/spicyramen/opencall/blob/Development/config/standalone-sip.xml
Move standalone-sip.xml file to this director:
mss-2.0.0.FINAL-jboss-as-7.1.2.Final/bin and
mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/configuration
  • Obtain local system information
Obtain local IP address information and define which NIC system will be using ifconfig
Example:
ifconfig
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384            options=3<RXCSUM,TXCSUM>            inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1            inet 127.0.0.1 netmask 0xff000000            inet6 ::1 prefixlen 128gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280stf0: flags=0<> mtu 1280en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500            ether 20:c9:d0:42:af:7d            inet6 fe80::22c9:d0ff:fe42:af7d%en0 prefixlen 64 scopeid 0x4
inet 192.168.1.69
netmask 0xffffff00 broadcast 192.168.1.255            media: autoselect            status: activep2p0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 2304            ether 02:c9:d0:42:af:7d            media: autoselect            status: inactive
  • Verify iptables or firewall is open for ports 5060,5061 and 5062.
  • Start Mobicents server
Go to the following folder in order to start Mobicents server:
  • Run the command:
./standalone.sh -b 192.168.1.69 -c standalone-sip.xml &
Opencall Installation
  • Download Opencall  war file
https://github.com/spicyramen/opencall/blob/Development/target/opencall-1.1.0-BELADOR.war
  • Create Opencall folder
Create opencall folder in mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/configuration
Example:
mkdir mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/configuration/opencall
  • Download and configure Opencall server init file (opencall.ini)
https://github.com/spicyramen/opencall/blob/Development/config/opencall.ini
Configure proper file location inside Opencall.ini define path for Opencall server routing rules.
MODE=1
RULE_LIMIT=100
FILELOCATION=/Users/gogasca/Documents/OpenSource/Development/Java/Mobicents/mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/configuration/Opencall/Opencallrules.cfg
  • Download and configure Opencall server call routing rules
https://github.com/spicyramen/opencall/blob/Development/config/opencallrules.cfg
  • Deploy opencall war file
Move Opencall war file to the Mobicents deployment folder:
mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/deployments
Verify Opencall war is deployed successfully, verify Opencall log and server log file in log folder: the Opencall log file is named: Opencall-engine.log, server log is server.log
Example:
  • Server
21:55:33,724 INFO  [org.jboss.as.server] (ServerService Thread Pool -- 29) JBAS018559: Deployed "
opencall-1.1.0-BELADOR.war.deployed"
  • Opencall log
16:10:32.095 INFO  [Opencall] [Thread-160] | Opencall engine has started succesfully.
  • Deployment folder
WebSockets Installation
  • Download Websockets war file*
http://repo1.maven.org/maven2/org/mobicents/servlet/sip/examples/websockets-sip-servlet/2.0.0.FINAL/websockets-sip-servlet-2.0.0.FINAL.war
            *File may be already included in Mobicents zip file, so this instruction may not be required.
  • Deploy WebSockets war file
Verify Websockets war is deployed successfully, verify server log file in log folder: the server log file is named: server.log
  •             Server
            21:55:33,723 INFO  [org.jboss.as.server] (ServerService Thread Pool -- 29) JBAS018559: Deployed "websockets-sip-servlet-2.1.0-20121108.113957-1.war"
  • Deployment folder
websockets-sip-servlet-2.1.0-20121108.113957-1.war.deployed
Webrtc2sip Installation
Follow the instructions described here, if you want to enable media conversion:
You have the option to install from source or install the packages:
http://autostatic.com/installing-webrtc2sip-on-ubuntu-1204#building_from_source
Configuration
Mobicents configuration
For Mobicents please make sure you configure configuration file properly.
Configure your Default Application Router Configuration and define the proper Application Name.
INVITE:            Opencall
REGISTER:     WebSockets
Opencall configuration
Configure opencall.ini and define the initial system configuration settings
Configure opencall.ini and define the System Routing rules in order to connect Mobicents to your external system.
Opencall System Configuration
Opencall server will look for opencall.ini located:
mss-2.0.0.FINAL-jboss-as-7.1.2.Final/bin and mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/configuration/opencall in order to start succesfully
opencall.ini
MODE
1 - LOCAL FILE
2 - DB (MYSQL DB)
3 - LOCAL RULES (BUILT-IN) (Not implemented)
DB TYPE
DB TYPE
1 - MYSQL                                         TODO
2 - MONGO DB                                  TODO
3 - MICROSOFT SQL SERVER           TODO
MODE 1 must have FILEROUTINGRULES
MODE 2 must have DBTYPE,DBHOSTNAME,DBPORT,DBNAME,DBUSERNAME and DBPASSWORD
MODE 3 does not need any parameters (Not implemented)
Example:
MODE=1
RULE_LIMIT=100
CALLTRANSFORMS=/usr/local/src/mobicents/mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/configuration/opencall/opencalltransforms.cfg
CALLRULES=/usr/local/src/mobicents/mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/configuration/opencall/opencallrules.cfg
CALLROUTELIST=/usr/local/src/mobicents/mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/configuration/opencall/opencallroutelists.cfg
DBTYPE=1
DBHOSTNAME=localhost
DBPORT=3306
DBNAME=opencall
DBUSERNAME=root
DBPASSWORD=
Opencall Route Configuration
Opencall have the option to read call routing rules from a configuration file or from a MySQL DB.
This document describes how to configure opencallrules.cfg to provide call routing rules in order to connect to your system.
Mandatory parameters:
       RULE      = NUMERIC
       PRIORITY  = NUMERIC
       TYPE      = REGEX,  WILDCARD, NUMERIC
       STRING    = VALUE
       TARGET    = IP ADDRESS, HOSTNAME, _DNS_, ROUTELIST
Optional
      PORT and TRANSPORT is not configurable when using _DNS_ lookup
      PORT and TRANSPORT is not configurable when using RouteList, you can define parameters there.
Rule Entries Order
RULE NUMBER,RULE PRIORITY, RULE TYPE, MATCH STRING,TARGET, PORT TARGET, TRANSPORT
Example:
ROUTE=("1","10","NUMERIC","14082186000","110.10.0.210","5060","UDP")
ROUTE=("2","5","REGEX","(.*)@videolab.att.com","_DNS_")
ROUTE=("3","10","NUMERIC","201","172.31.43.74","5060","TCP")
ROUTE=("4","10","WILDCARD","20X","172.31.43.74","TCP")
ROUTE=("5","10","WILDCARD","10X","110.10.0.200")
ROUTE=("6","10","WILDCARD","XXXXXXXX","videoalpha.att.com")
ROUTE=("7","10","WILDCARD","XXXXXXXX","videolab.att.com","WSS")
ROUTE=("8","100","WILDCARD","20X","110.10.0.210","5060")
ROUTE=("9","50","WILDCARD","0115255!","110.10.0.200","5060")
ROUTE=("10","50","WILDCARD","0115233!","110.10.0.200","5060")
ROUTE=("11","1","NUMERIC","+525553259000","110.10.0.200","5060")
ROUTE=("12","1","WILDCARD","4XX","110.10.0.220","5060")
ROUTE=("13","100","REGEX","(.*)@.*","_DNS_")
ROUTE=("14","5","REGEX","(.*)@videolab.att.com","_DNS_","5061")
ROUTE=("15","5","REGEX","(.*)@videolab.att.com","_DNS_","TCP")
ROUTE=("16","100","REGEX","(.*)@videolab.att.com","12.5.4.3","TCP")
  • Verify Opencall war file is deployed successfully.
$ pwd
/Users/gogasca/Documents/OpenSource/Development/Java/Mobicents/mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/deployments
$ ls -al
-rw-r--r-- 1 root root      11 Feb 28  2013 jolokia.war.deployed
-rw-r--r-- 1 root root 1169838 Nov  6 07:58 opencall-1.1.0-BELADOR.war
-rw-r--r-- 1 root root      26 Nov  6 07:58 opencall-1.1.0-BELADOR.war.deployed
-rw-r--r-- 1 root root    8870 Jul 16 22:33 README.txt
-rw-rw-r-- 1 root root  408732 Nov  6 00:37 sip-servlets-management.war
-rw-r--r-- 1 root root      27 Nov  6 00:37 sip-servlets-management.war.deployed
-rw-rw-r-- 1 root root  649785 Nov  6 00:35 websockets-sip-servlet.war
-rw-r--r-- 1 root root      26 Nov  6 00:35 websockets-sip-servlet.war.deployed
WebSockets configuration
  • After verifying websockets war file is deployed successfully, you can proceed to configure sipML5
$ pwd
/usr/local/src/mobicents/mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/deployments
$ ls -al
Chrome configuration
  • Open Chrome and verify you have network connectivity to Internet and local server where Opencall is running.
SipML5 configuration
The live demo doesn't require any installation and can be used to connect to any SIP server using UDP, TCP or TLS transports. Open the following URL and start provisioning information. Open the following URL:
http://sipml5.org/call.htm
2 Comments
ivelin117
Beginner
Great article. Since the original post, Telestax and Orange developed and published an open source WebRTC browser client framework, which integrates tightly with the server side components.
https://code.google.com/p/webrtcomm/
The popular jain-sip library that's used on the server side is now fully ported to Java Script and supported. We also introduced a web developer friendly API, which hides much of the low level APIs that require VoIP expertise.
Here is a blog post with the latest WebRTC frameworks from Telestax in action.
http://www.telestax.com/livechat-and-video-call-with-restcomm/
Ivelin
ivelin117
Beginner
Update on the Open Source project used in this blog. Restcomm 7.3 , which builds on SIP Servlets, now includes client side and server side WebRTC components that work together and provide a smooth turn-key end user experience. Suitable for private and public cloud deployments.
A couple of related resources:
http://www.telestax.com/restcomm-7-3-0-is-here/
http://www.telestax.com/enterprise-webrtc-call-center-for-banking-and-finance-with-restcomm/
Ivelin
Content for Community-Ad
Spotlight Awards 2021
