Welcome to the Community Enhancement Idea Exchange. Share your ideas to improve Cisco Community and vote on the ideas you like best.
How to use the Idea Exchange:
  • Feature enhancements: Suggest features that would make the community easier for you to use.
  • Add comments: Comment to add your thoughts to another member's idea.
  • Vote on ideas: Help shape the future of the community by voting on your favorite ideas.
Every idea will be reviewed by the Cisco Community management team. You can follow the state of an idea by the Status, such as "Under consideration" "Accepted" or "Declined".
We look forward to everyone collaborating to make our community the best it can be!
Status: New
The Platform gives us the opportunity to Like the Comments on
ISE Deployment and Operation Lessons from Large Complex Environment - Like Button Comment.png
but not for
Navigating Security in a Chaotic Environment - Part I - Like Button Comment.png
Including the option to "Like the Comments" on Knowledge Base Articles not only standardizes the document format, but also fosters better engagement between Authors and their Readers.
Why not do it ?
2 Comments
RedNectar
This would be especially helpful for those posts which have been answered, but never acknowledged as answered.
@RedNectar ,
 I really like using the Like Button along with Comments, I believe it generates better engagement and communication, and unfortunately, this feature is missing in Knowledge Base Articles.
 You mentioned something that frustrates me a lot: a Post with many good answers, but no Likes and, most importantly, no "Accept as Solution".
 To give you an idea of ​​the ratio of Views vs Likes, one of my most viewed Knowledge Base Articles (90K+ Views) only has 70 Likes, which is less than 0.1% ... ISE - Queue Link Error
