07-27-2022 02:38 PM - edited 08-23-2022 10:32 PM
Many (hundreds) of post no longer display preformatted (i.e. between html <pre></pre> tags) properly when published - although the text DOES display properly when in edit mode.
This is how I found out - I happened to be looking at an old post reply of mine. What I saw was:
Now, if I edit the post, I see everything views as it should:
Now I COULD go through the many many posts I've posted with <pre></pre> blocks (that USED to work fine) and change them to <li-code lang="markup"></li-code> blocks (which is what is now used when you click theInsert/Edit code sample icon,
BUT even that does NOT produce a suitable result, because it wraps text when it shouldn't. When posting code sample, line wraps can create a whole new meaning to your post.
I've highlighted two major flaws in the new system
07-27-2022 04:00 PM
Hi @RedNectar - thanks for raising this issue, I'll get it reported!
10-23-2022 12:07 PM
Hi @Tyler Langston ,
Could I ask you to bump this? Almost 4 months and no progress.
11-03-2022 02:33 PM
Hi @RedNectar - I'm so sorry that I missed this notification (I've been doing a lot of board and category-level subscription testing in the past few months and my notification feed is a nightmare).
The 'pre' issue is slated for fix in this month's release which should be around the 15th, barring something unusual happening. Thanks again for your detailed OP, and patience as dev worked on it!
