Tunnel traffic through ZBFW
1487
Beginner
I am trying to configure ZBFW in the MID router, using the following topology:
The main objective is allowing the following protocols to pass from the TEST zone to NODO_SUC zone, with the condition that the communication must start in the TEST zone:
  • udp
  • tcp
  • ssh
  • icmp
  • isakmp
When I try to ping from 11.0.0.3 to 10.0.0.2 it works, and when I try to ping from 10.0.0.2 to 11.0.0.3 it does not work (it is OK). The problem is when I try to ping from 192.168.1.2 to 192.168.1.1, through the tunnels, it does not work. I would like to know what's the problem here.
The configuration from both tunnels in the routers is the following:
Sucursal#sh run int tun1
Building configuration...
Current configuration : 118 bytes
interface Tunnel1
ip address 192.168.1.1 255.255.255.252
tunnel source 10.0.0.2
tunnel destination 11.0.0.3
end
Sucursal#
Test2#sh run int tun1
interface Tunnel1
ip address 192.168.1.2 255.255.255.252
tunnel source 11.0.0.3
tunnel destination 10.0.0.2
end
Test2#
I have posted the configuration from the MID router for any question about it.
Thanks & Regards,
Franco Riggio
Content for Community-Ad
