9300 Sudden Reboot issue
Yowmamen
Hi to all, I just installed my newly purchased catalyst 9300-48s. However when running it, the device experienced reboot. There is no interval time when the device will reboot. It will just reload unexpectedly.
"Show version' result
Last reload reason: Power-on
When I issue show environment: everything is OK
I tried to check power rack supply and power cable and everything is OK. I also tried to put the power module on the vacant slot but still the problem occur.
Im not sure if this is a hardware/power module issue or an ios bug.
Im currently running 16.12.3a CAT9KI_OSXE
Yowmamen
@Leo Laohoo hi sir. This is my new thread
Leo Laohoo
Ok, I want the complete output to the following command:
show logging onboard switch active uptime detail
