Rating post not possible after responding to it
Peter Paluch
Dear friends,
It seems that the ratings still have a small glitch. Immediately after I post a response to a thread using the simplified editor, I cannot rate any posts in the page until I reload it. The stars for ratings are displayed, however, hovering over them does not produce the usual pop-up/callout with the verbal description of the grade, and clicking on any star makes the browser to simply jump to the top of the displayed page. I have confirmed this behavior both in Firefox and MSIE.
This problem does not appear if I start responding and afterwards, I cancel my post before posting it. Only immediately, after successfully posting a new response to a thread, the ratings cannot be entered until the page is reloaded. The issue does not appear to be limited to a particular forum.
Does anyone have similar experiences? Thank you!
Best regards,
Peter
7 Replies 7
Rob Huffman
Hi Peter,
Yes, I'm seeing the exact same behavior my friend
So now I go with the "Rate first-respond later" plan ..... hahahaha!
Cheers!
Rob
Daniel Bruhn
Level 8
Level 8
Hi Peter,
Thanks for passing this along.  Our development team is looking into it.
Cheers,
Dan
Cheers, Dan
Hi Dan,
Thanks a lot!
Best regards,
Peter
I am testing the ability to rate your post after replying (using FF 5.0)
Confirmed in FF - now testing IE 8.
anogno
IE8 worked coirrectly, but only because another issue with the IE8 browser and replying caused a refresh.
I will file a bug and see if we can't have this ironed out.
testing
