05-29-2014 08:15 AM - edited 03-14-2019 01:28 PM
Hi Everyone
This Is a discussion we'll be having with our vendor but I'd like to do a little research before we get to that point.
We currently have CCX 8.0 with WFO 8.0 (Advanced). We're looking at a potential upgrade to 10.0 which may include a jabber rollout. We've got the following requirements and wonder if we could achieve it using cisco/calabrio platforms.
Does anyone know if this is possible? I've been hearing more and more about mediasense but I'm not sure what it can do for us.
Robert
05-30-2014 11:46 AM
Cisco Finesse is included in UCCX 10.0, you will be OK.
The record part should not be difficult, for screen recording, if your Calabrio version supports it, you should be ok.
You don't need to install anything on the client PC's for audio recording, but you need to have a client in the computer for screen recording.
Not sure, if the integration between UCCX and Jabber is already present for v10, but you can uses CIPC without problems :)
References:
Hope this helps!
Rolando Valenzuela
06-26-2014 08:50 PM
I think only mediasence is the recording option if you want to use Finesse.
can someone confirm?
HM
08-30-2015 08:01 AM
Dear,
according to the document below:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/crs/express_10_6/design/guide/UCCX_BK_CBB99111_00_cisco-unified-contact-center-express/UCCX_BK_CBB99111_00_cisco-unified-contact-center-express_appendix_0111.html#UCCX_RF_F672AC20_00
you can use either QM or mediasense for finesse recording.
