05-08-2022 01:48 AM
Dear Members,
I have enabled after call work for UCCX for 20 Sec, but for some reason its not seems configured correclty. Seeking some assisstance for the same.
Solved! Go to Solution.
05-10-2022 12:57 AM
Are you actually using Agent Based Routing? If not you're looking at this in the wrong place. Check your CSQ settings. An example of how it looks one one of our systems and queues is attached below.
05-09-2022 10:20 PM
Please share screenshots of your configuration so that we can verify it.
05-09-2022 10:45 PM
05-10-2022 12:57 AM
05-10-2022 02:09 AM
05-10-2022 02:28 AM
That depends on your specific requirements, so I cannot really give you an answer on this.
05-10-2022 02:22 AM
Thanks Roger it worked for me
