Hello
Test deployed to CVP-11
Using an audio element to play an audio file that is 45 seconds long of instructional information, and the barge in option is checked.
Once the audio completes, or is barged in upon the next element is a form playing a TTS prompt with recognition.
During the playing of the 45 second audio I try to barge-in (using speech, and DTMF) but the audio continues to play.
I was under the impression that CVP would detect the barge in attempt during the 45 second audio causing the audio stream to stop, but I'm not seeing this behavior.
Appreciate any details of how barge in support should work with the playing of an audio file.
Configuration content for the audio play:: (Barge in is not detected)
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<!DOCTYPE configuration SYSTEM "../../../../dtds/VoiceElementConfiguration.dtd">
<configuration class="com.audium.server.voiceElement.audio.MAudio" serial="0000">
<audio_group bargein="true" count="1" name="initial_audio_group">
<audio name="audio item 1" src="/CVP/audio/TEST/TEST-5-Greeting.wav" use_default_path="true"/>
</audio_group>
</configuration>
Looks a conf error to me, did you restarted the VXML Server or redeployed the app after modifications ?
Please check the gateway logs by enabling debug logs and see if the barge in is enabled for the element.
