04-07-2008 11:45 PM - last edited on 03-25-2019 07:10 PM by ciscomoderator
Hi all.
After installing CAD (CCX 5.01 and CME)following error appears:
LRM non active, contact administrator.
Ideas?
Solved! Go to Solution.
04-08-2008 12:04 AM
The error message is saying License Resource Manager is not starting, loaded or something went wrong with it install.
Check if you have any subsystem stopped with meaningful error messages or try reinstalling I would say just for the IPCCX side.
Riccardo
04-08-2008 12:04 AM
Riccardo
04-08-2008 10:12 PM
Hi.
The reinstallation of IPCCX (repair) solved the problem.
Thank you a lot
06-02-2008 01:35 PM
Hi guys
I have excatly the same error message and did the repair but with no success.
Do you have somethimg else in mind?
