01-11-2012 02:03 PM - edited 03-14-2019 09:10 AM
Is it possible to run two different versions of CAD on the same pc. We are upgrading on new servers to 8.6 UCCX and customer wants to leave old version CAD for backout.
I dont think it will work.
Any ideas
01-11-2012 02:59 PM
No it is not, it will defect previous version and will only allow an upgrade.
HTH,
Chris
01-11-2012 03:01 PM
You could use CAD-BE until you are sure you will not be backing out, then upgrade the client on the computer. CAD-BE has it's limitations though.
Brian
01-11-2012 11:04 PM
I concur Brian.
GP.
