CAD two versions same pc
miket
Contributor
Contributor
Is it possible to run two different versions of CAD on the same pc.   We are upgrading on new servers to 8.6 UCCX and customer wants to leave old version CAD for backout.
I dont think it will work.
Any ideas
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
No it is not, it will defect previous version and will only allow an upgrade.
HTH,
Chris
brian1mcc
Enthusiast
Enthusiast
You could use CAD-BE until you are sure you will not be backing out, then upgrade the client on the computer. CAD-BE has it's limitations though.
Brian
I concur Brian.
GP.
Recognize Your Peers
