1115
isilo0001
Beginner
Call Studio 10.5 projects with Maven
We're trying to convert our Call Studio 10.5 projects to Maven projects in order to automate  the build and deploy processes. Has anyone ever tried to do so? What problems did you come across? We're trying to find the suitable plug-in version for Call Studio 10.5.
1 ACCEPTED SOLUTION
Mohan Karki
Beginner
We use Jenkins, Maven and SAB to automate build. Within Jenkins, Maven builds the jarfile, use batch commands to copy the jar files into the deploy/lib folder and execute buildApp.bat to create build and deploy the using powershell script. We were on CVP8.5 and now upgrading to CVP10.5. The issue we are facing is that SAB is missing in CallStudio 10.5 install.
2 REPLIES 2
Ryan Burtch
Enthusiast
How does Maven compare to other Repo systems such as GIT or SVN?
Mohan Karki
Beginner
Create
Recognize Your Peers
Content for Community-Ad
