Can we use IP communicator and hard IP phone same time for a single agent
ali.raza0407
Beginner
Beginner
Dear all,
Is it possible that we can create a agent and use the cisco IP communicatore and hard IP phone at same time for that agent. These two phones will work as a backup. If hard phone goes down it will automatically switch to soft phone and vice versa. Can you please share the configuration details with me for that?
Best Regards,
AR
9 REPLIES 9
Tanner Ezell
Enthusiast
Enthusiast
You don't mention the ACD solution you're using, so I will answer for a UCCX configuration:
No, shared lines are not supported on the UCCX platform.
Tanner Ezell www.ctilogic.com
Thanks for you reply tanner.
I am talking about UCCE solution. Can we support this feature in UCCE. Do we support this backup mechanism in UCCE. This is a requirement from customer. They want to use these two phones (hard and soft phone) as a backup.
BR,
AR
You can't run them both at the same time.  If one of them goes down and you launch the other one then yes you can use it as a backup.  You will have to log back in.
david
Hi David,
It mens, we will add mulitple phones undera a single account. Than we will login with that acount by using only a single phone. If that phone goes down than we need to login in another phone manually. right?
BR,
Ali
