CCE Test environment requirements and best practices
Elliot Dierksen
VIP Engager VIP Engager
VIP Engager
I have a customer with a PCCE environment, and they are interested in setting up a test environment. The test environment doesn't need the same level of redundancy as production, but I am wondering if the best practice would be to have a separate CUCM cluster for the test environment. I am sure I will need a CVP server. How much can/should I combine to keep the number of VM's down? Meaning should I keep router, logger, PG separate? Do I need a separate admin workstation? CUCM and PCCE are both version 12.5.
david.macias
VIP Advocate VIP Advocate
VIP Advocate
Don't overthink it and just do the PCCE Lab Deployment and just add water. https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/pcce/pcce_11_6_1/maintenance/Guide/pcce_b_admin-config-11_6/pcce_b_admin-config-11_6_appendix_010111.pdf This is great for validating patching and testing new things. I would have my own UCM.
david
Recognize Your Peers
