07-02-2011 04:09 PM - edited 03-14-2019 08:10 AM
Hi. I have a problem with my CCX version del sistema: 8.5.1.11001-35,
. When I try login in the CCX Administration Page, It is very very slow for load the main menu, but when I login in other windows page, these load normal.
please your help
Thank you
Jagifoto1
Solved! Go to Solution.
07-02-2011 04:49 PM
Hi Javier,
if you have configured ccx cluster (pub and sub) first at all check connectivity both pub and sub. Also I recomend you confirm servers configured in unified cm configuration list, maybe there is some device with some problems.
I hope this help you.
07-02-2011 04:49 PM
Hi Javier,
