05-01-2012 09:21 AM - edited 03-14-2019 09:47 AM
Got a customer we're planning on upgrading from UCCX 7X to 8X. They are currently integrated with an external SQL DB. I understand I need to download the appropriate driver for 8X for SQL. The question I have though is whether the UCCX scripts themselves need to be updated as well or will the 7X scripts that have the typical DB read/get/write/release work when I do the migration?
Solved! Go to Solution.
05-01-2012 01:31 PM
They should work as-is but your only way to be sure is to test them. I would only anticipate an issue if you were doing complicated logic that CCX didn't support in the first place. Simple SELECT queries should continue to be fine.
PS- Don't use the Microsoft driver, use this: http://jtds.sourceforge.net/
05-01-2012 01:31 PM
05-01-2012 01:39 PM
As always, thanks for the help! I did see the sourceforge link from other discussions. Many thanks.
