05-16-2008 08:37 AM - last edited on 03-25-2019 07:11 PM by ciscomoderator
Hi all
we experiencing problems with integration indicated.
Sometimes CCX stop all services. Reading logs and event viewer appears to be an ldap error (ERROR LM0012 Monitor::Run:: Slapd process died) and (LC0012 LDAPConnectionMgr::EstablishConnection:: Failed to bind to LDAP server on <10.2.3.34>).
Someone has ideas on this?
05-22-2008 11:59 AM
try the following:
- Ping LDAP from CAD server by IP and by hostname
- Check if any ports are blocked.
- Check the network bindings in case you have 2 NICs on the server.
- Check if ODBC conneciton is working fine
- Cisco LDAP Monitor is restarting probably becasue it is not able to contact the LDAP.
05-22-2008 10:27 PM
thank you for help, but there's no LDAP server because integration is with Communication Manager Express.
There's only one NIC.
Regards.
