Walkthrough Wednesdays
454
antraxa31
Beginner
Cisco CVP Help
I must to create some way to obtain the total calls(IN) over a Cisco CVP solution, this solution(Cisco) is already installed and working properly. But here nobody has any knowledge about cisco CVP.
For this reason, i have no idea for how to get information about every incoming call over this Cisco CVP. Somebody would help me about it?
Does exist some webservice in cisco CVP for consulting that information?
or
Can i create anything over the Cisco CVP for send this information?
Any help is welcome.
Thanks.
3 REPLIES 3
jacparke
Contributor
If you have configured a CVP Reporting server, then you can read that data out of the Call table, or one of the Call summary tables (call_15, call_daily, call_weekly, call_monthly).  If you have a CUIC server configured, there are stock reports that will do all of that for you.
Jack Parker
gorourke
Rising star
Antraxa,
It depends on what you need to find out.
If you only need to find out how many calls arrived into the CVP Servers, then you can run a query against the RCD table on ICM.
While a CVP Reporting Server would inform you on details on the actually call flow users took within CVP application.
Note: the RCD (Router_Call_Detail) table is not a summary table, so run out of hours and / or limit your SQL query to run on a single thread (Google - OPTION (MAXDOP 1)).
Below is a query which groups by DialedNumberString.
You coudl add a filter for Routing Client so you would see only calls for CVP Routing Client(s).
SELECT DialedNumberString, COUNT(DialedNumberString) As NumberOfCalls
FROM Route_Call_Detail
WHERE DateTime > (DateAdd(hh,-1,GetDate()))
GROUP BY DialedNumberString
ORDER By DialedNumberString
Gerry
hemal.mehta
Contributor
There are many ways to do this. What kind of setup do you have ? Do you have reporting server and CUIC. You can get this info from some of the standard CVP reports in CUIC.
Depending on what exactly you need, you could also write some queries and custom scripts to get this info.
Hemal
Content for Community-Ad
