Hello all,
I'm sorry but I'm not familiar with the IVR from Cisco.
I have 2 different toll free numbers, do I need to order 2 IVR's or 1 can do the job?
Thanks in advance for the help.
Jeferson.
Solved! Go to Solution.
You might want to look into a UC5xx system which will provide simple prompting and routing. Maybe Unity like it was suggested above. You can have a million TFNs going to one IVR or two or a million IVRs. You really should reach out to someone with a bit more experience to ensure you get what you need and will meet your future needs.
david
Well, there are several products to meet those needs, to include a voicemail system that can provide simple prompt and collect.
It all depends on what you are doing with those numbers?
Do they point to two different DNIS?
For reference, a UCCX system can handle 300 callers simulatneously, and that's not even the biggest solution they offer.
Hello Anthony,
so, does not metter how many numbers I have?
The situations is like this:
0800 7775568 - 1st toll free number, the calls goes to a hunt group with 5 agents.
0800 7774578 - 2nd toll free number, this will have 4 option to choose from and each option takes to a different hunt group.
My question is, I ll request a quote from a provider, do I need to quote 2 systems or 1 will do what I need?
david
