Walkthrough Wednesdays
2158
Cisco Sip Dialer (8.5) problems with customer call
I have SIP Dialer 8.5 is conected directly to a voice gateway Cisco 2851 with IOS c2800nm-entservicesk9-mz.151-3.T4.bin, regisered 2 phones with number 1010 and 1020 at CUCM 8.6.
All services PG and Dialer in active state.
Login in CTIOS Desktop (phone number: 1010, id agent: 7500). For test I make a call from Dialer to number 1020.
Agent reserved system but call fail.
Log file from gateway:
10.3.3.3 - Dialer
10.3.3.11 - Gateway
10.3.3.6 - CUCM
448 - dialer port
1010 - agent phone
1020 - customer phone
Dec 16 13:30:02.269: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:1020@10.3.3.11 SIP/2.0
Via: SIP/2.0/UDP 10.3.3.3:58800;branch=z9hG4bK-d8754z-89061269042a8a62-1---d8754z-;rport
Max-Forwards: 70
Require: 100rel
Contact: <sip:448@10.3.3.3:58800>
To: <sip:1020@10.3.3.11>
Call-ID: ea7a8534-9e02137e-44052e46-8e39203c
CSeq: 1 INVITE
Session-Expires: 1800
Min-SE: 90
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, UPDATE, NOTIFY, PRACK, REFER, NOTIFY, OPTIONS
Content-Type: Multipart/mixed;boundary=uniqueBoundary
Supported: timer, resource-priority, replaces
User-Agent: Cisco-SIPDialer/UCCE8.0
Content-Length: 530
Remote-Party-ID: <sip:@10.3.3.11>;party=calling;screen=no;privacy=off
--uniqueBoundary
Content-Type: application/sdp
Content-Disposition: session;handling=required
v=0
o=CiscoSystemsSIP-GW-UserAgent 2884 2524 IN IP4 172.19.155.41
s=SIP Call
c=IN IP4 0.0.0.0
t=0 0
m=audio 19994 RTP/AVP 0
a=inactive
--uniqueBoundary
Content-Type: application/x-cisco-cpa
Content-Disposition: signal;handling=optional
Events=FT,Asm,AsmT,Sit,Piano
CPAMinSilencePeriod=608
CPAAnalysisPeriod=2500
CPAMaxTimeAnalysis=3000
CPAMaxTermToneAnalysis=30000
CPAMinValidSpeechTime=112
--uniqueBoundary--
Source Filename: ccapi_16_12_dialer1
*Dec 16 13:30:02.277: //18653/006583A78908/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 16 Dec 2013 13:30:02 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Dec 16 13:30:02.289: //18654/006583A78908/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:1020@10.3.3.6:5060 SIP/2.0
Via: SIP/2.0/UDP 10.3.3.11:5060;branch=z9hG4bK62588
To: <sip:1020@10.3.3.6>
Call-ID: 67F4E0-658D11E3-890EF0A5-EBD428B4@10.3.3.11
Supported: timer,resource-priority,replaces,sdp-anat
Require: 100rel
Min-SE:  1800
Cisco-Guid: 0006652839-1703743971-2299064485-3956549812
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1387200602
Contact: <sip:10.3.3.11:5060>
Expires: 180
Max-Forwards: 69
Content-Length: 211
v=0
o=CiscoSystemsSIP-GW-UserAgent 310 2097 IN IP4 10.3.3.11
s=SIP Call
c=IN IP4 10.3.3.11
t=0 0
m=audio 18030 RTP/AVP 0 19
c=IN IP4 10.3.3.11
a=rtpmap:0 PCMU/8000
a=rtpmap:19 CN/8000
a=ptime:20
Dec 16 13:30:02.313: //18654/006583A78908/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 420 Bad Extension
To: <sip:1020@10.3.3.6>;tag=2062172177
Date: Mon, 16 Dec 2013 13:39:16 GMT
CSeq: 101 INVITE
Allow-Events: presence
Unsupported: 100rel
Content-Length: 0
Dec 16 13:30:02.317: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:1020@10.3.3.6:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Dec 16 13:30:02.317: //18653/006583A78908/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server Error
To: <sip:1020@10.3.3.11>;tag=5B51B1C-2647
CSeq: 1 INVITE
Reason: Q.850;cause=127
Content-Length: 0
17 REPLIES 17
Gergely Szabo
Advocate
alright, did you check the usual suspects, for instance, is there a SIP trunk between the GW and CUCM. Also, can you post the outbound SIP dial-peer from the GW to CUCM. Should be something like this:
dial-peer voice 2001 voip
  description SIP REFER -> CUCM
  destination-pattern .T
  session protocol sipv2
  session target ipv4:10.20.30.40 !CUCM address
  voice-class sip rel1xx supported "100rel"
  no voice-class sip reset timer expires 183
  dtmf-relay sip-notify
  codec g711ulaw
  no vad
G.
voice service voip
ip address trusted list
  ipv4 10.3.3.0 255.255.255.0
allow-connections sip to sip
signaling forward none
sip
  bind control source-interface Loopback22
  bind media source-interface Loopback22
  rel1xx require "100rel"
dial-peer voice 51 voip
incoming called-number .T
voice-class sip rel1xx require "100rel"
codec g711ulaw
dial-peer voice 52 voip
destination-pattern 1...
session target ipv4:10.3.3.6 !CUCM address
codec g711ulaw
Hi, can you just try replacing the voice-class sip line in the outbound dial-peer with voice-class sip rel1xx supported "100rel".
G.
I change voice-class sip rel1xx supported "100rel" for dial-peer's,
but the problem persists
Gergely Szabo
Advocate
Hi, can you please rewrite the destionation-pattern expression in the outbound dial-peer to .T - if possible, just for testing.
Also can you confirm the IOS version is 15.x? It won't work with older versions.
G.
Sent from Cisco Technical Support Android App
Нi, I am rewrite dial-peer, and now dial-peer look like:
codec g711ulaw
#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ENTSERVICESK9-M), Version       15.1(3)T4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
Okay, I would like you to set up SIP tracing in CUCM. Do you know how to do that?
Thanks.
G.
Trace file from CUCM in attachment (enable all detail trace)
this
15:10:58.696 |//SIP/SIPHandler/ccbId=0/scbId=0/getRel1xxType: No matching SIP trunk found in hash table, returning rel1xx disabled|1,100,230,1.50^10.3.3.11^*
15:10:58.696 |//SIP/SIPHandler/ccbId=0/scbId=0/sipSPIGetCallExtensionSupported: SIPRel1xxEnabledServiceParamSetting=0 , ccb->pld.outboundRel1xx=1|1,100,230,1.50^10.3.3.11^*
15:10:58.696 |//SIP/Stack/Error/0xf3a3340/Bad Extension - Require header processing failed.|1,100,230,1.50^10.3.3.11^*
is a bit suspicious.
Is there a SIP trunk configured in CUCM, pointing towards the GW?
Also, can you please try removing the rel1xx require "100rel" command from the voice service voip > sip section?
Also, is there a CVP involved in here?
G.
New configuration gateway, new debug call (agent login on phone 1010, call customer phone 1020, 1030, 0635878424)
I dont have CVP, I use IPIVR
On CUCM I have trunk with destination 10.3.3.11, specific security profile and normalisatin script according Outbound Option Guide
for Cisco Unified Contact Center Enterprise and Hosted 8.5(1)
And I add in sip profile some change (problem not resolve):
Gateway:
voice service voip
  ipv4 10.202.0.0 255.255.0.0
sip
  bind control source-interface Loopback202
  bind media source-interface Loopback202
codec g711ulaw
description to_CCM
codec g711ulaw
no vad
Log call on number 1020(cucm) - not call, 1030(cucm) - not call, (0635878424(pri) - when dialer call on mobile number I recive call, but call not transfer to agent - file CUCM in attachtment log_cucm.txt
OK, let's take a look at it from a different angle.
What does the agent see? Can you give me a screenshot of it?
G.
Reservation agent:
when I recive call on mobile phone, string reservation disappears
Oops.
You should use the other CTI Toolkit Desktop, the one with the Outbound Option buttons (Accept, Reject, etc).
If you chose the default installation options, it's
"C:\Program Files\Cisco Systems\CTIOS Client\CTIOS Toolkit\Win32 CIL\Samples\CTI Toolkit Outbound Desktop\CTIOSOutOptSSoftphone.exe"
Can you also confirm that the dialing mode is Preview or Preview-Direct?
Thanks.
G.
In CTI Toolkit Outbound Desktop same situation, only buttons not active when reservation occure...
Dialing mode is Predictive
Content for Community-Ad
Spotlight Awards 2021
