I've setup a Elastic SIP trunk using Public IP NAT'ting towards Cisco Voice Gateway.
Twilio(Elastic SIP Trunk)-->Public IP NAtting--->Cisco Voice Gateway--->CUCM
Public IP-115.111.182.150
We are trying a establish a incoming call using the above call flow.
Am able to see calls in Voice gateway. But I See few errors like SIP/2.0 100 Trying or SIP/2.0 404 Not Found.
The way I setup the call routing is when I call the main number (2177714466) the call is supposed to get routed to Cisco CUCM.
Translation Rule created is,
voice translation-rule 3
rule 1 /^\+/ //
voice translation-profile NEW
translate called 3
Dial-Peer:
dial-peer voice 7011111 voip
translation-profile incoming NEW
destination-pattern 721..
progress_ind alert enable 8
session protocol sipv2
session target ipv4:10.131.62.146----CUCM IP
session transport udp
incoming called-number .
voice-class sip rel1xx supported "100rel"
voice-class sip profiles 1
no voice-class sip reset timer expires 183
dtmf-relay sip-notify
codec g711ulaw
no vad
Attaching the VG Configs and debugs. Can you guys help to sort out this issue
Anto
Define your incoming DNIS in "incoming called-number" and test once.
incoming called-number 90046812400521
codec g711ulaw
no vad
INVITE sip:90046812400521@115.111.182.150 SIP/2.0
Via: SIP/2.0/UDP 193.46.255.79:63702;branch=z9hG4bK1001664554
Max-Forwards: 70
To: <sip:90046812400521@115.111.182.150>
Call-ID: 111393798-1473263611-2106785414
Have made few changes in the Translation rule and in the dial-peer,
rule 1 /.*/ /72100/
destination-pattern 72100
codec g711ulaw
Now calls are getting connected.
But the issue here is once call is getting connected and if I accept the call in Cisco phone immediately calls are getting disconnected
Also I see "delay media to slow start case, codec negotation is not done" in the debugs.
Attaching the debugs and configs.
Could you guys help on this issue.
Anto
