6523
Stefan McIntyre
Beginner
Cisco Unified Call Studio 10.5 New Call Studio Project not available
New CVP 10.5 Install, the option in my installed Call Studio is not there to create a Call Studio Project as should be, stated in:
User Guide for Cisco Unified CVP VXML Server and Cisco Unified Call Studio Release 10.5(1) - Introduction [Cisco Unifie…
Any help or guidance on this sparsely documented product would be greatly appreciated!
1 ACCEPTED SOLUTION
XP, Windows 7 or 8 to get any support.
10 REPLIES 10
Travis Cassell
Beginner
I've got the exact same problem.  Were you able to resolve your issue?
Nope. No one has responded and I have no local resources with any experience with this product.
Help me Cisco Communities, you're my only hope.
Never fear, young Padawan!  Your conundrum is being reviewed by the CVP team. One of them should reply soon.
Thank you Jeffrey, truly a paragon of the Jedi ways. I shall meditate upon this and wait for your reply.
Travis Cassell
Beginner
Stefan, hope you didn't install it on Server 2008 because they won't help you.  Just got off the phone with TAC and they refused to assist me because it was installed on 2008.  Every install I've ever done has been on 2008 without issue but now it's not working and they don't do anything about it.
Best of luck!
What are we supposed to install it on? It can't run on the server itself?
After your post, I installed it on my Win8 VM and poof. Got the correct options. Crazy it isn't supported on the same Windows versions as the application itself.
Thanks Travis.
Per guide.
Installation and Upgrade Guide for Cisco Unified Customer Voice Portal, Release 10.5(1) - Pre-Installation [Cisco Unif…
Unified Call Studio (Optional)
Category
Requirements
Supported Hardware
2GB+ RAM required
Operating System
Windows Compatible
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows 8
Ahmad Abuhannoud
Beginner
Run eclipse as an administrator and open Builder Perspective
Create
Recognize Your Peers
Content for Community-Ad
