Cisco WorkForce Optimization Quality management external SQL server and internal storage case
kaito336
Dears,
We have installed cisco WorkForce Optimization Quality management 11.5 and I started Postinstall of external SQL server after that when I reach configuration of Recording Path I left it internal and error shown as below:
Please Advice.
Thank You and BR,
Thank You for Response,
Actually I already made QM in another server and I pointed it to SQL server but I solved Issue by adding QM cradentials to monitoring and recording API service after that it works fine.
Graham Old
Level 7
Level 7
What do you mean by "Postinstall of external SQL server"
If you are using an external SQL server you do not install any QM software on that server.
You would install a single server QM and you can point that to an external SQL server
Graham
