Connection issues of Historical Reports Client over a non-Cisco VPN/third party VPN
shridhar reddy
When trying to run the Cisco Unified CCX Historical Reports Client over a non-Cisco VPN, the user receives an error.
The major failure is the connection problem between Historical Reports Client and Cisco Unified CCX Server.
Error :
An error occurred while communicating with web server.
All available connections to database server are in use by other client machines. Please try again later and check the log file for error 5054.
This works fine when connected to through Cisco VPN .
Is the third party VPN/ customer's web based VPN blocking the connection between UCCX  server and HRC machine ??
Thanks !!!
Shridhar Reddy
anchoudh
Level 9
Level 9
Hi Shridhar,
Are you able to access the UCCX admin from non-Cisco VPN?
Please make sure that the no of HR sessions currently connected are under the no's specified in UCCX.
1. UCCX system parameters: Number of HR sessions
2. UCCX Admin->Tools->Historical Reporting->Database Server Configuration->Max DB Connections for Report Client    Sessions
Hope it helps,.
Anand
Please rate helpful posts !!
anchoudh
Level 9
Level 9
Hi Shridhar,
Hope it helps,.
Anand
anchoudh
Level 9
Level 9
Hi Sridhar,
Also please try accessing the database port 1504 from your client box.
Reference:
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_8_5/configuration/guide/uccx851pug.pdf
Hope it helps.
Anand
Pls rate helpful posts !!
