ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Beginner
Create TTS Prompt not shown on CRA Editor v3.0(2)?
I am unable to locate the Create TTS Prompt step under the Prompt palette using CRA Editor v3.0(2). Is there an upgrade needed for this?
Please advise.
Andrew
1 REPLY 1
Highlighted
Contributor
Re: Create TTS Prompt not shown on CRA Editor v3.0(2)?
Andrew,
You need the license for TTS .Without this you will not get the create TTS prompt under prompt palette.
Radhika
