06-24-2014 10:11 AM
Hello everyone,
We went live with UCCE 9.x a week ago, and I´m having some difficulties with measuring AHT in a correct way.
Right now, when our agents needs to do some after call-work, they put themselves on Not Ready with a reason code called "After call work".
When they´re done with that - they put themselves back on Ready.
But this reason code is never calculated into the ACW.
How do you report your AHT?
I´ve tried to combine the stock query"Agent Team Historical All Fields" with the query from "Agent Not Ready Detail" but I just can´t get it sorted. I would really appreciate some help here if this is possible.
Thanks a lot in advance!
Robert
Solved! Go to Solution.
08-04-2014 05:47 AM
Hmm, I think I was looking at that JOIN wrong. You should have a "RIGHT JOIN" instead of the "LEFT OUTER JOIN". That should take all appropriate rows from Agent_Skill_Group_Interval, and join them with any matching rows from the AED summary.
As an alternative, if you wanted to keep all of the JOINs as LEFT JOIN (probably an easier design to read), you can do this:
SELECT
Agent_Team.EnterpriseName as TeamName,
(Person.FirstName + ' ' + Person.LastName) as FullName,
SUM(ISNULL(ASGHH.CallsHandled, 0)) AS CallsHandled,
SUM((ASGHH.WorkNotReadyTime + ASGHH.WorkReadyTime + AED.Duration) / ASGHH.CallsHandled) as ACW,
SUM((ASGHH.TalkInTime + ASGHH.HoldTime + ASGHH.ReservedStateTime) / ASGHH.CallsHandled) as ATT,
SUM((ASGHH.TalkInTime + ASGHH.HoldTime + ASGHH.ReservedStateTime + ASGHH.WorkNotReadyTime + ASGHH.WorkReadyTime + AED.Duration) / ASGHH.CallsHandled) as AHT,
ASGHH.LoggedOnTime as LoggedOnTime,
PerReady = ISNULL(ASGHH.BusyOtherTime + ASGHH.WorkNotReadyTime + ASGHH.WorkReadyTime + ASGHH.ReservedStateTime + ASGHH.AvailTime + ASGHH.TalkInTime + ASGHH.HoldTime * 1.0 / ASGHH.LoggedOnTime, 0),
TimeReady = ISNULL(ASGHH.BusyOtherTime + ASGHH.WorkNotReadyTime + ASGHH.WorkReadyTime + ASGHH.ReservedStateTime + ASGHH.AvailTime + ASGHH.TalkInTime + ASGHH.HoldTime * 1.0, 0),
PerNotReady = ASGHH.LoggedOnTime - (ASGHH.BusyOtherTime + ASGHH.WorkNotReadyTime + ASGHH.WorkReadyTime + ASGHH.ReservedStateTime + ASGHH.AvailTime + ASGHH.TalkInTime + ASGHH.HoldTime) / ASGHH.LoggedOnTime,
NotReadyTime = ASGHH.LoggedOnTime - (ASGHH.BusyOtherTime + ASGHH.WorkNotReadyTime + ASGHH.WorkReadyTime + ASGHH.ReservedStateTime + ASGHH.AvailTime + ASGHH.TalkInTime + ASGHH.HoldTime)
FROM Agent_Skill_Group_Interval ASGHH
LEFT JOIN (SELECT
Interval=CASE WHEN (DATEPART(minute,DateTime)<>0 AND DATEPART(minute,DateTime)<>15 AND DATEPART(minute,DateTime)<>30 AND DATEPART(minute,DateTime)<>45) OR DATEPART(second,DateTime)<>0 THEN DATEADD(minute ,((DATEDIFF( minute,0 , DateTime)/ 15)*15 ),0) ELSE DATEADD(minute ,(((DATEDIFF( minute,0 , DateTime)-1)/ 15)*15 ),0) END,
SkillTargetID,
Duration=SUM(Duration)
FROM Agent_Event_Detail
WHERE SkillTargetID IN (:AgentSkillTargetID)
and DateTime >= :startDate
and DateTime <= :endDate
and ReasonCode = '71'
GROUP BY
SkillTargetID
) AED
ON AED.Interval=ASGHH.DateTime AND AED.SkillTargetID=ASGHH.SkillTargetID
LEFT JOIN Agent
ON Agent.SkillTargetID=ASGHH.SkillTargetID
LEFT JOIN Person
ON Person.PersonID=Agent.PersonID
LEFT JOIN Agent_Team_Member
ON Agent_Team_Member.SkillTargetID=Agent.SkillTargetID
ON Agent_Team.AgentTeamID=Agent_Team_Member.AgentTeamID
WHERE ASGHH.SkillTargetID IN (:AgentSkillTargetID)
and ASGHH.DateTime >= :startDate
and ASGHH.DateTime <= :endDate
GROUP BY
AED.Duration, Agent.EnterpriseName, ASGHH.CallsHandled, ASGHH.HandledCallsTime, ASGHH.LoggedOnTime, ASGHH.BusyOtherTime, ASGHH.WorkNotReadyTime, ASGHH.WorkReadyTime, ASGHH.ReservedStateTime, ASGHH.AvailTime, ASGHH.TalkInTime, ASGHH.HoldTime, ASGHH.NotReadyTime, Person.FirstName, Person.LastName, Agent_Team.EnterpriseName, Agent_Team_Member.AgentTeamID
- Jameson
06-26-2014 02:32 AM
Hi Robert,
%AHT (Average Handle Time Percentage) = Sum of Talk Time / Total number of Calls / interval length (in seconds) * 100
I would request you to refer Hold tim in Agent & Agent Skil group reports - Community - Cisco Developer Community
for related information.
Thanks and Regards,
Geevarghese
06-26-2014 02:58 AM
Hi Geevarghese,
Thanks for your reply - I appreciate it!
I´m aware of AHT is calculated as default - but we really require to merge the default AHT with Not Ready reasoncode 71.
The reason why is that we want to know how much the total AHT is, including the not ready state where the agent had to use the Not Ready state '71' to finish the case.
Thanks again!
06-26-2014 06:09 AM
Robert,
What is your reasoning for not using the built-in wrapup mode? Wrapup time would be much simpler from a reporting standpoint than a specific Not Ready reason code, as it's already included in stock AHT reporting.
-Jameson
06-26-2014 09:58 AM
Hi Jameson
When selecting "Work not ready" we are automatically set to "Not ready" with reasoncode [0] Undefined.
So after the set (in our case) 20 seconds wrapup, the state changes to Not ready..
Is there any function we are missing here? I would really appreciate an explanation on how it should work, and I´ll take it with our Cisco team.
Thanks!
06-27-2014 05:36 AM
Robert,
How are you selecting "Work not ready"? What agent desktop are you using?
There are two types of wrapup:
-Jameson
06-27-2014 06:55 AM
Hi Jameson,
We´re using CAD 8.5.4.33.
With the current set up we have, unfortunately I dont see any other option right now than to include the ReasonCode 71.
Would it be hard to get this figure into the "Agent Team Historical All Fields" report definition?
Thanks!
Robert
06-30-2014 08:31 AM
Robert,
I've personally never had a chance to use CAD, but looking at the user guide page 21, I see this:
Work Ctrl+Y
Changes your state to Work, indicating
that you are in wrap-up work after
terminating a call and, when finished, will
be available to receive routed calls
As I outlined before, the system should only put an agent in Work Not Ready if they were Not Ready before the call. If an agent was Ready before the call, the system should put them in Work Ready when they select the Work button, which would automatically go back to Ready after wrap-up time is up.
Adding calculations around Reason Code 71 is certainly possible if you have access to editing Report Definitions. You would have to grab data from the Agent_Event_Detail table. The thing that makes this more difficult, is you would likely have to write the SQL as an anonymous block, not a normal query. This is largely due to the need to summarize data from the Agent_Event_Detail table before joining it with the various tables in the Agent Team Historical All Fields report.
If you've got an issue with Work Ready mode functioning, I would endeavor to correct that... perhaps an issue for TAC.
-Jameson
07-29-2014 02:57 AM
Jameson,
Thanks for your reply!
I get your point - but the only workaround I see is to create a custom report definition.
I´ve started with it but it shows really strange figures for "Calls handled" - anyone who want to help me with this?
SELECT
A.EnterpriseName,
aed.SkillTargetID,
(t9.CallsHandled * 1.0) as CallsHandled,
aed.LoginDateTime,
Event = CASE Event WHEN 1 THEN 'Login (1)' WHEN 2 THEN 'Logout(2)' WHEN 3 THEN 'NotReady (3)' END ,
EventStart = DATEADD(ss,-Duration,aed.DateTime),
EventEnd = aed.DateTime,
aed.Duration,
Reason = rc.ReasonText + '(' + CONVERT(varchar(10),rc.ReasonCode) + ')',
aed.ReasonCode
FROM Agent_Event_Detail aed
LEFT OUTER JOIN Reason_Code rc on aed.ReasonCode = rc.ReasonCode
JOIN Agent A on aed.SkillTargetID = A.SkillTargetID
join Agent_Skill_Group_Interval t9 on t9.SkillTargetID = aed.SkillTargetID
WHERE aed.SkillTargetID IN (:AgentSkillTargetID)
and aed.DateTime >= :startDate
and aed.DateTime < :endDate
and aed.ReasonCode = '71'
group by
aed.LoginDateTime,
t9.CallsHandled,
rc.ReasonCode,
aed.ReasonCode,
rc.ReasonText,
aed.Duration,
aed.DateTime,
aed.Event,
CONVERT(VARCHAR(10), aed.DateTime, 120) ,
A.EnterpriseName
,aed.SkillTargetID,A.SkillTargetID
07-29-2014 06:22 AM
Robert,
You're likely getting a log of extra rows of data... you don't have anything limiting the DateTime range of Agent_Skill_Group_Interval, and you have nothing tying the Agent_Event_Detail records to your intervals either.
I don't understand why you're doing a GROUP BY statement, as you're not using any aggregate functions yet (SUM, MAX, COUNT, etc).
All the data in Agent_Event_Detail will need to be summarized in a separate query before joining with your other tables. Something along the lines of this:
SELECT
ColumnName1,
ColumnName2,
ColumnName3,
etc...
FROM
(SELECT
Interval=CASE WHEN (DATEPART(minute,DateTime)<>0 AND DATEPART(minute,DateTime)<>30) OR DATEPART(second,DateTime)<>0 THEN DATEADD(minute ,((DATEDIFF( minute,0 , DateTime)/ 30)*30 ),0) ELSE DATEADD(minute ,(((DATEDIFF( minute,0 , DateTime)-1)/ 30)*30 ),0) END,
SkillTargetID,
SUM(Duration)
GROUP BY
SkillTargetID
) AED
LEFT JOIN Agent_Skill_Group_Half_Hour ASGHH
LEFT JOIN more tables
and so on...
Computing the Interval for AED is a little tricky... more information on why I did is as above here:
https://supportforums.cisco.com/discussion/12263946/ucce-cuic-interval-boundary-agent-not-ready
The calculation is for 30-minute intervals... if you use 15-minute intervals in your environment it will take a bit more work to get it set up for that.
You won't need any GROUP BY in the outer SELECT statement unless you're doing any further aggregation after joining with ASGHH or ASGI, for example if you were to make a version of the report definition that summarized by Day, Week, or Month.
-Jameson
07-31-2014 03:27 AM
Jameson,
Thank you so much for the code example, I really appreciate it!
I didn´t succeed to make it work though, see my query below.
I´m getting the following error message:
Create the parameters or correct the query syntax and recreate the parameters. No column was specified for column 3 of 'AED'.
SELECT
aed.Duration as NotReadyDuration,
(ASGHH.CallsHandled * 1.0) as CallsHandled
FROM
(SELECT
SkillTargetID,
SUM(Duration)
GROUP BY
SkillTargetID
) AED
07-31-2014 05:54 AM
Robert,
Try this:
SELECT
AED.Duration as NotReadyDuration,
ASGHH.CallsHandled,
ASGHH.SkillTargetID
FROM
(SELECT
SkillTargetID,
GROUP BY
SkillTargetID
) AED
Looks like I forgot to name the SUM(Duration) statement.
-Jameson
08-01-2014 04:07 AM
That made the trick! I'm now able to get some data!
It looks a bit strange though - it does not get nearly as close as many calls handled in this report as on any stock agent report. I assumed there must be something wrong with the intervals so I changed the query to 15 instead of 30 mins.
I changed the table where I get the calls handled and so on.. maybe it has to do with this?
Any ideas?
SELECT
FROM
(SELECT
Interval=CASE WHEN (DATEPART(minute,DateTime)<>0 AND DATEPART(minute,DateTime)<>15) OR DATEPART(second,DateTime)<>0 THEN DATEADD(minute ,((DATEDIFF( minute,0 , DateTime)/ 15)*15 ),0) ELSE DATEADD(minute ,(((DATEDIFF( minute,0 , DateTime)-1)/ 15)*15 ),0) END,
SkillTargetID,
GROUP BY
SkillTargetID
) AED
LEFT JOIN Agent_Skill_Group_Interval ASGHH
LEFT JOIN Agent
GROUP BY
Output example ( I will group it with summary only later, don\t need any details per interval)
08-01-2014 06:05 AM
Robert,
Your Interval evaluation for 15 minutes is not quite right, try this instead:
Also, we should probably change the first join to an OUTER JOIN, as LEFT JOIN will only keep rows where your AED query has values. You'll have to add this to the outer query as well, otherwise there will be too much data after the JOIN change:
Your AHT, ATT, and ACW calculations are not going to work properly... I would rethink how you build them. Keep this in mind:
(A1/B1)+(A2/B2) IS NOT EQUAL TO (A1+A2)/(B1+B2)
You should SUM before division. I usually just save calculations like this for Formula Fields... it keeps the SQL query simpler, and makes it easier to build the custom footer for these fields (Never use a Sum or an Average footer for AHT and such).
-Jameson
08-01-2014 11:28 PM
Jameson,
It seems like it still does not fetch enough data from the _ table.
Also I couldnt get the "WHERE" into the outer join, error message.
Thanks for the hint about the calculations - I´ll focus on this as soon as I know the query gets all the data
Here´s the query after the latest changes.
SELECT
FROM (SELECT
SkillTargetID,
GROUP BY
SkillTargetID
) AED
LEFT OUTER JOIN Agent_Skill_Group_Interval ASGHH
LEFT JOIN Agent
LEFT JOIN Person
GROUP BY
