Custom class for playing system prompts
Vinay K M
I wanted to know is there any class file to play the system prompts from the user folder . Is there any reference or sample file to develop custom prompts.
Best Regards
Vinay
Jonathan Schulenberg
None of the available releases allow you to mess with the system prompts folder. In every scenario I can think of it is possible to modify your script to manually choose user repo prompts instead of the system repo file; it just takes more effort.
Is there a specific task that you're trying to accomplish? We can talk out what extra code you need to make it pull from the user repo.
