I'm not completely sure what you mean by "it shows up as "From CVP" and Caller ID". Where does it show up?
If you are talking about "--CVP"
"--CVP" is in the survivability.tcl on the gateway.
# CVP needs somthing to indicate that the call it is receiving was initiated from
# this script. displayInfo was one place to 'hide' an indicator. However,
# when ani is blank, displayInfo cannot be set. Therefore when ANI is blank
# set the usrDstAddr to a dummy indicator value (777#1212121212) for CVP.
# CVP in turn will simply strip the value from the incoming setup. The only
# possible drawbackis that the ARQ sent to the GK from this script will
# contain this dummy value as a secondary e164 id.
if {$ani == ""} {
set callInfo(usrDstAddr,0) "e164=777#1212121212"
} else {
set callInfo(usrDstAddr,0) "e164="
set saveDisplay [infotag get leg_display_info]
set tmpDisplay $saveDisplay
append tmpDisplay "--CVP"
set callInfo(displayInfo) $tmpDisplay
2. How are you handling your CUCM-originated calls? Is 8111111111 the vru transfer label on both CVP AND CUCM routing clients?
Geoff
