04-05-2013 06:28 AM - edited 03-14-2019 11:30 AM
Hi Everyone,
I need to clarify something about AWDB ,HDS And DDS,can you please someone explain me what is the difference between AWDB,HDS and DDS,
I was refer this post i can not see here detailed information
https://supportforums.cisco.com/thread/2177368
Kemal,
Solved! Go to Solution.
04-08-2013 07:19 PM
HDS by default it would retain the data for 1095 days,
Logger Database would retain 14 days of histrorical data.
HDS and DDS are not seperate databases while you look, If you look at your HDS database, there are tables as below
Termination_Call_Variable
Route_Call_Variable
Agent_State_Trace.
These tables contains the detailed informtion about the each and every Call and Agent.
HDS will have 15 and 30 minutes Intervals
DDS will have Details informtion about the Call
HDS and DDS are same database called as Data Server, just the tables make the difference what data it contains
Senthil
04-05-2013 08:35 AM
The difference the data what they have. Each databases have their own tables.
AWDB will contain only the Configuration Data and RelaTime Data
HDS will contain only the Historical Data
DDS will contain Detail information of each call.(call variable,Agent trace data)
Senthil
04-08-2013 07:00 AM
Hi Senthilkumar,
How long time data stored HDS and DDS, I know that ; HDS stored 14 days data by default.
Can you please more detailed.
04-08-2013 07:49 AM
Hi ,
Usually by default HDS data is stored for 100 days.
Data storagedepends on DB space available andit can be increased accordingly.
Refer the below http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/ipcc_enterprise/ipccenterprise8_0_1/maintenance/guide/icm80ag.pdf
04-08-2013 07:19 PM
Route_Call_Variable
Agent_State_Trace.
Senthil
