Community Helping Community
424
Highlighted
Beginner
Difference between CallsRoutedToday and CallsOfferedToday
                   Dear All,
I just want to understand,what is actul CallsRoutedToday and CallsOfferedToday.I went through Schema guide but not able to understand properly.Need your help on this.
1 REPLY 1
Beginner
Re: Difference between CallsRoutedToday and CallsOfferedToday
Mukesh,
The way I read it is CallsOfferedToday counts internal calls whereas CallsRoutedToday does not. I suppose you could easily verify this by running a route call detail report for calls and filter out the records from internal DNs and see if it matches the count of CallsRoutedToday.
HTH,
Jason
Content for Community-Ad
FusionCharts will render here
